Windows 7: Realtek Microphone Problems
02 Feb 2015   #1
Oscar2603
Windows 7 64 bit
Hi guys,
I've had this problem since I built this computer. Basically, my microphone is not working at all on my PC. When I plug my mic in, Realtek detects that it is a mic and all but then it does not pick up noises. It's not like it can't really hear it, it just thinks that the mic is disabled and is turned off or something. Another strange problem is that I cannot enable or change any settings in Sound in the Control Panel. I can make the changes and then hit ok, but when I open up the window again, it's back to previous default settings. I also cannot enable Stereo Mix and I also cannot open the "Set Up Microphone" wizard as it keeps saying it cannot launch.
So, the first thing I did was download newer drivers for Realtek HD Audio Manager from the ASUS site. It uninstalled the older ones and reinstalled the new ones. Once it restarted, there was no sound and the Speaker icon in the bottom right had a red "X" on it. Windows automatically troubleshooted and found that my audio devices had encountered a problem. So to get my sound back again, I had to do a System Restore.
I'm now very confused on what to do next. Could this be a hardware problem or is there something that I'm missing out?
I've had this problem for almost 6 months and this is my last resort for getting this fixed. Toms Hardware or even my PC Guru friends can't figure it out.
02 Feb 2015   #2
fireberd
I have a desktop with an ASUS P8Z77 LE Plus, which is probably similar to your motherboard. I have not had any problems with the RealTek. I'm using the R2.75 High Definition driver direct from the RealTek site.
However, just to see if it works with the Windows installed "High Definition Audio Driver" uninstall the RealTek and the drivers in the Device Manager. In the Device Manager, RIGHT click on the RealTek entry to highlight it and then LEFT click "Uninstall" Also check the box to uninstall the drivers. Restart the PC and when Windows starts Windows should detect the sound and install the generic High Definition Audio Driver. This is a basic driver and does not have all the extra features of the RealTek but it should be enough to see if the hardware works.
If the High Definition Audio driver works OK, go to the RealTek site and download the High Definition Audio Codecs for Win 7 64 bit (R2.75).
Realtek
02 Feb 2015   #3
Oscar2603
Windows 7 64 bit
I'll give that a go and see how it works. Will post back in a few minutes.
Also, I don't have a sound card. I use 3.5mm speakers.
02 Feb 2015   #4
Oscar2603
Windows 7 64 bit
I have uninstalled Realtek and Windows automatically installed the HD Audio Codecs. However, I have no sound. It has the speaker icon with the Red X at the bottom. Troubleshooting says that the "Audio Device is Disabled"
I have Realtek HD Audio Codecs downloading and hopefully that will bring my sound back. If not, I will have to do a System Restore.
02 Feb 2015   #5
Oscar2603
Windows 7 64 bit
I fixed it! Looked up the problem with no sound and can't change settings and found a report on PC Gamer about it. Turns out all I needed to do was change the access for users to change Audio Processes. So I went into Command Prompt (ran as administrator)
and typed in:
net localgroup Administrators /add networkservice
net localgroup Administrators /add localservice
And rebooted and it worked! So happy right now, was dreading having to reinstall windows. Thanks Fireberd for the help too though, I'm almost 100% sure it wouldn't have worked had I not done what you said
Realtek HD Audio microphone not working
Hi there, I have recently built my own computer for the first time, and it seems to have gone pretty well. The only problem is that I can't seem to use a microphone, and it's really frustrating. First of all, when I plug the microphone into the front panel, the computer thinks i've Unplugged it....
Problem with microphone when plugged to PC front port, Win 7 & Realtek
If i connect my headset with microphone to port in my PC's front, it notifys both new microphone (line out) and headphones (line in) (no usb, dont remeber what its called in english, ports also working cause notifys new devices). I have Windows 7 installed and Realtek HD Audio Manager and its...
Realtek microphone problem
So, I have a realtek internal microphone, long story short, 2 days ago it worked, now it doesn't. I tried to make a call from my computer and the other individual couldn't hear me, so I opened my sound recording software to test my mic and it didn't work. I checked my settings and they all make...
Microphone problem (Realtek)
I have windows 7 64bit and I have: High Definition Audio Controller PCI Realtek ALC888/1200 @ ATI SB700 - High Definition Audio Controller PCI When I put in microphone, nothing happens and detect only: -Speakers (working ok) -Digital audio (s/pdif) (hight definition audio device) I'v...
Microphone not wroking[Realtek issues]
Hey,new here, anyway here is my problem : I recently bought a new computer, got windows 7 ultimate, everything worked so fine xD till i got to try the microphone...seems like i have an ALC 889 Realtek HD integrated audio, and the funny thing is that it reads my microphone but no sound, only...
Realtek HD and P5N-D Microphone problem
Hello, i searched this forum for an answer but i didn't find any. I run on Seven build 7000 but i can't get my microphone to work =s I updated my Realtek drivers to R2.16 but nothing works. My microphone is detected but it does not work, i tried to plug it on the front and rear. I'm a little...
