Windows 7: Sound blaster Live! Value card - no sound
03 Feb 2015   #1
goldenhound104
Windows 7 Ultimate 64-bit
Done the research, and unless I've missed something, there's a caveat that hasn't been addressed in this issue.
I have an SB Live! value card, have installed the Daniel_K driver for it, following the suggestions about deleting the existing RealTek (which didn't seem to work, though I didn't put *any* time into why that didn't work), and scrubbing the system with the recommended driver scrubber - can't remember the name but it was recommended in an earlier post.
I *record* with the SB Live! value card because of the low-noise, and rock-bottom price that these are now available for. On-board sound has terrible noise floor issues. They all do. I occasionally play games with the analog joystick, and attach to the midi port to back up my Roland VG-8 guitar fx box. The card is fully utilized in my system, so I don't want to switch to the on-board garbage.
So, back to the problem. The Daniel_K drivers installed well, BUT, though I see the VU meter in the system tray responding on playback (i.e,, it jumps around indicating that Windows is trying to send the signal to the card), I get no sound out of the speakers. I've tried headphones with no joy. I've also tried the KX drivers (nice effort btw, but no midi, or joystick drivers with the KX stuff), with the same result. No sound from the card.
No IRQ conflicts, no DMA issues, etc. I've tried it in the only other slot on the mobo.
BTW, mobo is new, and uses the AMD SB710 southbridge. Does that Southbridge just not pass sound, or? Card works on my dual-boot XP, so I know its good.
Suggestions? Anyone seen this particular wrinkle before?
Thanks in advance!
03 Feb 2015   #2
fireberd
Most new motherboards only have a "bridged" PCI slot to the PCIe bus. Many PCI cards will not work or work properly with the bridged PCI slot. There are many posts about this on the recording forums.
04 Feb 2015   #3
goldenhound104
Thanks for your reply, Fireberd. I don't understand what is meant by a "bridged" pci slot to the PCIe slot. Can you give me more detail? Are you saying that the PCI services for the two PCI slots I have are somehow connected to the PCIe? What does that mean in English?
Any idea how I can find out for sure if the asrock 960gc-gs fx uses a bridged pci slot?
04 Feb 2015   #4
fireberd
The PCI slots are not true PCI slots in "bridged" applications. They do not have a separate PCI bus, they are connected ("bridged") to the PCIe bus.
The specs that I looked at do not say how the PCI slots work.
I have a recording studio (I use Sonar) and a separate USB connected recording interface unit will work much better, both in Signal to Noise and latency. Even an inexpensive interface will be better than an PC sound card.
Here is an example of a low cost unit.
Lexicon Alpha USB Desktop Recording Studio | Musician's Friend
04 Feb 2015   #5
goldenhound104
Thanks Fireberd for the excellent link to the Alpha usb recording interface.
Of course, all I want to do is belly-ache about how much more complicated and expensive it is now to do things separately than it used to be with one card. The SB Live! value card has a very good noise floor, midi-capable, which enabled me to hook up a midi keyboard, and upload/download my Roland VG-8 patches, analog joystick that I use for rudder pedals as well as the joystick for European Air War / Flight Simulator 2004.
It's the nature of technology to make people go out and buy replacements for everything that has been working reliably for years, sometimes decades.
The Technology Sauron - One card to do it all...and in the darkness bind them?
sound blaster live does not work
hey my sound blaster live dosențt work at all it says that it is installed and everething seems fine ... just does not work
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Sound blaster live!
The right drivers at the last post: http://www.sevenforums.com/sound-audio/79428-sound-blaster-live.html#post694541
Sound Blaster live
Please help. I have installed Win 7, but when I want to install Sound Blaster live software, it says that no sound card is installed. I installed the kx software and the sound works, but I cannot use my midi keyboard and somehow my micr0phone will not work in Skype. I would realy like my...
Hardware & Devices
Sound Blaster 5.1 Live!
hi at everybody. i'm new on this forum... yesterday i've installed windows 7 on my desktop pc, but i've some problems with audio card : model -> Creative Sound Blaster Live! 5.1 where i can find correct drivers for this audio card??? thanks a lot
Drivers
