Windows 7: I have no sound when my laptop is on battery power
05 Feb 2015   #1
kevil0922
It goes like this: my laptop is normally plugged in, high performance power settings, battery taken out. Every once in a while I put the battery in and use it with normal charge/discharge cycles, power saving settings. Now it somehow happened that when I put the battery in and windows booted up I had no sound whatsoever. Chrome or AIMP2 are not recognized in the volume mixer, and skype notified me that it was unable to access the sound card. When I put it to sleep and then woke it up again the sound came back. I then followed the same steps: shut down windows, booted up, no sound, put it to sleep, woke it up, sound available, a few times and always with the same "results".
Does anyone have any idea what's going on ? This never used to happen before.
05 Feb 2015   #2
fireberd
Reinstall the sound driver and see if that makes any difference. Sleep and what does or does not work after waking can be driver issues.
How is it booting? From a "cold" boot or booting up from Hibernate. If its booting from Hibernate that can be the cause of the problem (shouldn't be but can be).
05 Feb 2015   #3
kevil0922
Cold booting. I do have hibernate enabled, but I rarely use it, and when I do it's on AC because that's how I keep it primarily.
Edit: I have reinstalled the realtek audio driver in the device manager this time and it appears that it fixed it. Thank you !
Update: it just lost sound again this morning and after putting it on sleep and waking it up, the sound came back? Seriously what is going on?!
Replaced battery on laptop, Battery not taking charge.
Hi Guys, I have replaced the battery of my laptop after using it on AC supply for about year after my old battery died. I get this error message. "The AC power adapter type cannot be determined Battery may not charge. This problem might be solved by: Connect a Dell 65W AC adapter or...
Hardware & Devices
Laptop powers off unexpectedly at 20% battery left. 1YearOld Battery..
Hello there, I have an one year-old ASUS K53S Laptop, Windows 7 Home Premium 64bits, 6GB Ram and 500HDD. At the beginning, my battery lasted >3 hours in Balanced power mode (which is the one I alway use) and now due to regular use it last about 2 hours. Everything normal until here. About...
General Discussion
BSOD After Replacing Battery on Laptop, Power Driver Failure
I've read around a bit but nothing seems to be fixing my problem. My battery on my laptop died a few months back. I got the battery replaced last month and ever since I've been experiencing the BSOD for power driver failure once or twice a day. It rarely occurs while the laptop is in use. It's only...
BSOD Help and Support
Broken AC power jack, no battery power, help
Hi. Im new on this forum, but I have a problem with my Inspiron 1545 laptop from Dell pre-loaded Windows 7 Home Premium 64-bit (although I did re-install several times with OEM OS restore disc). Money is tight for us now, so my AC power jack on the side of my laptop (or the end which connects to...
Hardware & Devices
BSOD when running laptop off battery power
About 4 months ago I performed a number of upgrades to my 4 year old Lenovo SL400 laptop. I upgraded to a Seagate Momentus hybrid drive, upgraded my CPU, installed new RAM, purchased a new 9-cell battery and performed a clean intstall of Windows 7 Home Premium 64-bit (the computer came with...
My laptop running on BATTERY and giving error 'No battery detected'
my battery was giving 1.5 hour power backup from last 4 months... then last month it decreased to 1 hour...from couple of days it decreased to 1/5 hour(with error 'Consider replacing new battery') and yesterday i was using on battery power... and battery had 34% power remaining.. suddenly battery...
General Discussion
