I need Help Setting up My Xbox one microphone on my pc.
  1. Posts : 1
    When I go to look for it in my sounds it does not show up, even when I show disabled devices. Can some one help me?
    What type of connection (plug) does the microphone have? Is it a standard stereo plug (Tip, Ring, Sleeve) or is it a four conductor plug, Tip Ring, Ring, Sleeve? If its a four conductor you will need an adapter to use it with a PC.
