Windows 7: Stereo Mixer and Wireless USB Headset; Mic not mixing with audio.
17 Feb 2015   #1
Serph
Windows 7 Home Premium 64-bit
So I've only recently discovered Stereo Mixer and have been messing around with it for a few days. I've looked high and low for solutions on getting it pick up on my mic, but nothing works. I've read that it won't work with USB headsets, but I want to be sure of it before I give in and buy a new one.
I've set my speakers are the default playback default, headset as the default recording with Mixer as the default communications device, as well as vice-versa in regard to recording devices. I've also set "Listen to this device" in the Mixer to play back through my headset and tried without it checked off. I've gone so far as to use VAC with 3 audio repeaters in some roundabout way to try to get it to work, but still no luck. More details on that of anybody asks.
I have a friend who got it to work flawlessly, and he has a wired headset. I'm using a PlayStation Gold Wireless Headset, so I'm almost positive the headset is the problem. Does anyone have a better solution to this or am I just gonna need a new headset? If so, any suggestions? Preferably within the $80-$100 range.
18 Feb 2015   #2
fireberd
The Stereo Mixer should be sets as the default "Recording" device. Then any recording device that is plugged in and recognized by Windows can be used.
I don't have a wireless mic so I can't try it in my system.
However, the wireless connection and pairing must be done first. If this is not done then it won't work as Windows will not see the mic and/or headset. This is the first step, get it connected and Windows recognizes the devices. Its not the Stereo Mix problem, the problem is basic - getting it connected and working with Windows.
18 Feb 2015   #3
Serph
Yeah, dude. I know to connect the chingus into the other chingus for the chingus to work with the other chingus. My problem is that it's Stereo Mixer not recording my mic, I can use the headset just fine for things like games and Skype. I've already tried setting the Mixer as default and default communications, as well as mixer; default, mic; default communications and mixer; default communications, mic; default.
I've also used this roundabout method, but had no luck with that either.
USB headset doesn't get Stereo mix
When i plugin my USB headset I hear some audio sources but not all, Stereo Mix doesn't seem to appear for the headset. If i reboot the machine then everything is fine.. Any help on how I can avoid having to reboot?
No Stereo Mixer in Recording Devices
I have Windows 7 Pro SP1 32 bit laptop. It's a ThinkPad Lenovo T60p by IBM. I've been searching google for ever and ever but I cannot find a fix. Here is a screenshot of my Recording Devices: http://i.imgur.com/cB5Ui.png I found this via Google: forum.thinkpads.com • Stereo Re-mix...
can't find Conexant sound card stereo mixer driver
I have a new ACER Aspire 5250-0810 and i have not been able to find a stereo mixer. This is not a huge deal. But i would like to share music i am listening to while video chatting w/out having to use mic. The sound is distorted and i don't want chat partner to hear me. Is there no Stereo Mixer...
Drivers
Using Stereo Mix with USB headset?
Tried couple of ways but i cant get achieve my goal. i'm trying to do a commentary of so games so i need to record game sound and allso my headset sound (microphone) But since it's USB to not 3.5mm plug i cant find way to record both. i own a Realtek Driver and a Gigabyte Motherboard. i do not...
Stereo Mixer Not found as in XP
guys i am facing a problem i have windows 7 and in place of stereo mixer there is a recording playback option so can anyone tell me how to install stereo mixer or to use that option like used in xp???
Getting mic inout to show up in the stereo mixer
I'm using CamStudio to record online conferences, and I need to be able to record the audio not only from the speakers but from my microphone as well. I've done everything that the CamStudio gurus and forums have advised, and watched numerous videos on YouTube with directions on how to get the...
