Windows 7: Audio error 1079 and 1086 help!
23 Feb 2015   #1
Invictus
Windows 7 Home Premium 64 bit
I know that this is a common issue. I can't run the Windows Audio service. I've tried the playing audio troubleshooter, checked the services manually, uninstalled and reinstalled the drivers. The red "x" is still above the speaker logo. The power is running in services as well. All the needed dependencies are started. Windows audio endpoint builder boots as 'started', but will wind up hanging on starting after trying to start Windows Audio. This issue randomly happened after I installed blutooth drivers for my usb dongle to have better functionality with my PS3 controller. When this occurred, my theme was set to basic, and I did not have a connection to the internet. Now the audio services not running is the last issue here. I feel like I tried everything, but maybe I'm missing an option that actually works.
Specs:
Windows 7 64 bit Home Premium
16gb 4x4 ram
AMD Phenom II @3.8ghz
HIS Radeon HD 6770
24 Feb 2015   #2
Invictus
Please can someone provide me with a solution?
24 Feb 2015   #3
fireberd
Most of these, that I see posted, wind up having to reinstall Windows 7 (a clean install).
24 Feb 2015   #4
Invictus
I can't really afford a reinstall of Windows 7. There has to be a way to fix this. I read most sources saying the issues i had about internet connectivity and my display theme being stuck on basic would lead to a Windows 7 reinstall and there wound up being solutions.
24 Feb 2015   #5
fireberd
I'm just reporting what most have involved. Depending on the specific issues there are some that were able to fix it, but the majority that I've seen have had to do a reinstall.
As this happened after the Bluetooth driver install. Try a System Restore with an available restore point that is before the Bluetooth and problem. Someone with more OS knowledge may have more suggestions. That may be an issue for a different forum section, even though its a sound problem.
24 Feb 2015   #6
Invictus
I don't have any restore points thst date back that far unfortunately.
25 Feb 2015   #7
Invictus
Help would be much appreciated soon.
Windows Security Center - error 1079
My Windows Security Center wouldnt start so i tried - Start->Run,then type Services.msc and enter.Find the Security Center service right-click it,select Automatic and select Start. but after selecting start i get Error:1079 message. can anyone help on this? thanks
System Security
peer networking grouping error 1079
I really need help. I can't get peer networking grouping to start. when i go into services ant try to manually start it it gives me error 1079: the account specified for this service is different from the account specified for other services running the same process. someone please help :D
Network & Sharing
Error 1079
the areo glass on my windows is not working. i ask windows to fix it, but it can't, surprise surprise. anyways, i get this error message when i try to manually start the service ( Desktop Window Manager Session Manager ) that windows said to get running to get aero glass to work: *Window could...
Graphic Cards
