Windows 7: Can't hear sound through headphones, but it says sound is playing?
27 Feb 2015   #1
DavidG731
Windows 7 Home Premium
It was working and then I hit something in the realtek HD audio manager by accident and it stopped working, I can't figure out how to fix it.
27 Feb 2015   #2
fireberd
Not knowing what you did, all we can do is guess and try to help you.
Not sure if System Restore (back to an available restore date that is before whatever you did) will help or not, but one option to try.
Uninstalling/reinstalling the RealTek will probably do it. Actually just installing the latest RealTek will first uninstall the existing, have you restart the PC (Important step do not bypass this) and then will do a new install.
Download the latest High Defintion Codec from RealTek. Realtek
03 Mar 2015   #3
Daphne
Windows 7, 64 bit
you can right-click the sound icon on the notification area and select "Playback device" and then check whether the "High Definition Audio" is set as the default one or not. If not, just set it as the default one.
Realtek AC'97 Audio - Cant hear any sound from headphones or speakers.
I just bought a pc, windows 7 32bit. I tried to use my headphones but couldnt hear any sound, also tried speakers still no sounds. The green bar goes up on the volume control tho. I have tried downloading some drivers, but they didnt work. Im a novice when it comes to things like this, can...
Headphones not being recognized correctly or playing sound
Howdy-hey, everybody. Lately, my Acer Aspire laptop hasn't been able to play sound from headphones, or recognize that I have headphones/earbuds plugged into the headphone jack. A scan for my headphones from the "Add a device" option doesn't turn up anything. In fact, the last solution I tried...
Audio sound intrrupting while playing mp3 with headphones
Iím facing this problem while playing the audio files(like mp3, wav...etc) with front panel headphones, the sound interrupting continuously (like 10 seconds sound-1 second mute-12 second sound-1 s mute-5 s sound-1 s mute) but there is no problem while playing video files. I opened the mixer from...
Sound Recorder: I can't hear the sound
Several months ago I used Sound Recorder to record some songs using a USB microphone. I wrote in a file name and then played the songs back on Windows Media Player. When I recorded some songs this morning I went through the same steps but even though I saw the file in the WMP window, I could hear...
No sound from built in speakers, but sound from headphones
I have a Lenovo S10-3 Netbook, running on Win7 starter. It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers. Drivers are all up to date, and audio/sound settings are all...
I can hear 'Sound' but can open sound menu to adjust it
Hi, I am having a weird problem. I can actually hear sounds and talk with other people. It all works fine. But I can open any sound menu's or options. None of these icons/ menus are working.
