Windows 7: Conexant AC-97 Audio
10 Mar 2010   #41
salaadin19
Windows 7 x64 Pro Retail
Quote   Quote: Originally Posted by love2us View Post
I have a hp pavilion laptop which was running through window xp but now I made a change to window 7 every thing works fine except audio ac'97 can't start what shall i do please help me
Try the steps here love2us: ZV6000 Audio x64 solved These are the steps that I took to get audio working on my HP Pavilion zv6000, and another user for his HP Pavilion zd8000, so it is a pretty universal solution for ac'97 on win7 x64. (It is universal since the zv6000 is an AMD desktop-cpu-in-a-laptop platform with conexant ac'97 and the zd8000 is mobile P4 with intel IHC6 ac'97, so chances are you will fall somewhere in that range of configs )
hope that helps, let us know results. make sure to use the poll on ZV6000 Audio x64 solved as well
26 Mar 2010   #42
aeroform
Mac OS X Snow Leopard and Windows 7
Hp dv1660se sound issue resolved
It took me countless hours to finally fix the sound problems for HP DV1660 and probably DV1000 laptops.
Click on the link below and click on the first link posted. Download the driver and the sound should be fixed.
High Definition Audio on HP DV1000/DV1610TN Fixed
05 Apr 2010   #43
TrePaul86
Win7 Ultimate
AAAAAWWWWEEESOME!!!! Thanks Aeroform! Worked like a charm!
06 Apr 2010   #44
Cheril
Windows 7 x 64
Display drivers also
Quote   Quote: Originally Posted by Crawfo View Post
Here are some updates on the stutter problem. Both solutions were picked up from the Windows 7 Beta Microsoft TechNet Forum.
You can change the speaker settings to 16 bit, 22059 Hz (AM Radio Quality) but you will loose some in the sound. If you have lousy speakers it won't matter.
The best solution is to download the conexant ac97-61410599.exe driver file. Open this file using WinRAR (WinZip won't work). Extract camc6aud.sys and camc6hal.sys. Rename them camcaud.sys and camchal.sys (in short, remove the 6 from the filename. Copy these files to c:\windows\system32\drivers\.
Be sure to reboot the system so the new drivers will load.
I can't wait to try this solution. Does this mean that you guys have had success with the ATI Mobility Radeon X6 Dispaly Adapter? I certainly can't use that one, and the Microsoft Standard VGA Graphics Adapter streches the screen width.
There are no drivers for the Mass Storage Controller, or PCI Modem. Any bright solutions would be welcome.
02 May 2010   #45
ewald
Windows 7 Home Premium upgrade
Conexant 61410599 won't work on Pavilion zd8000 Noteboo
I downloaded this file,
extracted the files with WinRAR,
renamed the two files by removing the (6), then
copied them to Windows>system32>drivers.
Lastly, I then rebooted. But..still I have no sound.
What am I not doing?!
02 May 2010   #46
neo101
WIN7 Ultimate 64bit
Quote   Quote: Originally Posted by feeeeelfree View Post
I am using gigabyte in built realtedk audio chip, it was working fine with XP2 & XP3 but it gives a little lower sound with windows 7 and also the Bass is very low. I used all latest drivers from gigabyte and realtek as well, but the problem is same. I am using John Barrel's 5.1 Home theatre and it was working fine with my previous Windows. I love windows 7 & and i dont want to quit.
Pleeeeeeeeeeeeeeeeeeeeeeeeeeeees HELP!
Is there an option you can 'check' which says allow "full range" speaker (poss where dolby digital setup menu is)?
That pumps full digital range/bass thru your headphone/speakers.
Check thru your menus!
03 May 2010   #47
salaadin19
Quote   Quote: Originally Posted by ewald View Post
Don't take this wrong way, but did you actually go through and install the driver for the device (via device manager)?
03 May 2010   #48
Phone Man
Quote   Quote: Originally Posted by Cheril View Post
Its been a while since I did my HP laptop and my notes are fussy.
I used SP43509 (TI Card Reader Vista 64) and it worked.
I used SP35736 (PCI Modem vista 64) and had to add the ID to the inf file. Check the inf files on these two and see if they match your ID's
Jim
conexant HD audio not working windows 7 64 Bit
I have encountered issues with Conexant HD Audio driver. When I install driver there will be no sound and when I uninstall it there will be sound. Here I am attaching my computer specifications. Thank You. http://i.imgur.com/i1Lvffo.png
Conexant AC-Link Audio Drivers
Hey folks, I've been looking for the driver that's compatible with Windows 7 for this integrated sound, and I can't seem to find it. I've included the Hardware ID below. Any help would be much appreciated. Thanks in advance.
Drivers
Mic Problem (Conexant HD Smart Audio 221)
Hi, Ive been looking for a solution for so long ! Looked everywhere and no answers so i am posting here. My problem is that when i plug in an external mic, it does not work but the internal mic does work. I am running HP G60-348CA Windows 7 Conexant HD Smart Audio 221 (Date released:...
Conexant AMC Audio
Hi, I am looking for the windows 7 drivers for Conexant AMC Audio. Toshiba Satellite L20 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179&REV_02 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179 PCI\VEN_1002&DEV_4370&CC_040100 PCI\VEN_1002&DEV_4370&CC_0401
Drivers
Conexant AC-97 Audio HELP, PLEASE!
Hello everyone, I hope everbody's doing well. Please, I do really need your help to fix a problem with my Sound Card ''Conexant AC-97 Audio'' I have recently insalled Windows 7 Ultimate 64-bit and it seems to be working fine, though this particular issue with the sound card drivers. I have...
Issue with Conexant Audio driver
Hi all, I'm experiencing some issues with my Conexant audio driver and I'm hoping someone could help me out. I have a Toshiba P100-437 laptop and for some reason my audio stops working after a couple of reboots. So here is the scenario: I install a fresh copy of Win7. It installs a "High...
Drivers
