Conexant AC-97 Audio
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 42
    Win7 Ultimate
       #31
    Ok one thing I did notice, when I used the HD drivers, the speaker has the red x and the mute button stays lit up on the keyboard. When I use the AC-97 Drivers (sp34634.exe from HP) the red x is still over the speaker but the mute button is no longer lit.
    Is there a step by step someone can write up for me? Starting with uninstalling any drivers related to the sound, what driver to install (hoping I have the right one, sp34634.exe) and what order to go about things? I have a feeling I'm not typing something in right and it's causing it to not work right.
  2. Posts : 8
    Use the ID Strings as found in the Device ID in Control Panel. They need to match in order to allow the driver to work.
  3. Posts : 8
    I will write up a step by step as soon as I can boot the laptop and open the text file to read.
  4. Posts : 42
    Win7 Ultimate
       #34
    Awesome thanks man. I appreciate it!
  5. Posts : 28
    Windows 7 x64 Pro Retail
       #35
    did you try the step-by-step here?
    did you try the steps here:
    ZV6000 Audio x64 solved
  6. Posts : 28
       #36
    TrePaul86 said:
    Where is the "flags" section? I'm going to download and extract the sp34634.exe again, but not install, restart the computer and do what you said with "disable driver signature enforcement. I've been trying to install manually, but no luck... This is so frustrating!
    The flags are right below the "[Conexant.NTamd64]" section.
  7. Posts : 42
    Win7 Ultimate
       #37
    So if there's flags, delete them from the .inf file?
  8. Posts : 28
       #38
    not necessarily
    You don't have to necessarily, just check to make sure your hardware id isn't listed in there. Although, it couldn't hurt to get rid of it completely either :)
  9. Posts : 2
    yal2009meet@gmail.com
       #39
    I have a hp pavilion laptop which was running through window xp but now I made a change to window 7 every thing works fine except audio ac'97 can't start what shall i do please help me
  10. Posts : 42
    Win7 Ultimate
       #40
    Hey riverrat, were you able to get a how to up? I'm still without sound and it sucks! lol
