Windows 7: Annoying Sound issues with DVDs
08 Mar 2015   #1
Labrador
Home Premium 64
Hello all,
I have an annoying problem with my PC. When watching DVDs in 5.1 surround sound I get a little crackling/popping noise from every few seconds when the FL and or FR speakers are in use, but never from the centre speaker on its own, even after 10 or 20 minutes of dialogue. In theory I might suspect a short or some other fault with those two speakers, but they work beautifully for hours on end when playing music in itunes. I've got the latest drivers for motherboard and soundcard, but to no avail. The soundcard is a Terratec Aureon 7.1 (set to 5.1) with Teufel 5 speaker set up. All of the right noises come out of the right speakers, but like I said there's those infuriating crackles when a DVD uses the satellites. Other specs are AMD FX8300, 16GB of ram and 480GB Crucial SSD. There's onboard sound, but I've set it to disabled. Graphics card is a GT630. I've done some latency checks and uploaded the results; it looks like several drivers are problematic, but what's the reason?
08 Mar 2015   #2
fireberd
I would try the on-board sound, just to confirm whether its the sound card or some other problem. You have to start somewhere and that is a good starting point. Disable or even better remove the separate sound card for testing.
There is not a "one fix" for these types of problems, each one can be a different problem.
As you have a Gigabyte motherboard, do you have the Gigabyte EasyTune installed? This is a known cause of high DPC. When I first built my new recording studio desktop, I used a Gigabyte motherboard and when I installed the drivers from the Gigabyte install disc, I just installed everything. I was getting popping/crackling and dropouts on the audio. In my case, the EasyTune program was the problem. As soon as I uninstalled (and rebooted) the DPC Latency and the sound problems went away.
08 Mar 2015   #3
Labrador
Home Premium 64
Hi fireberd, thanks for replying. I've tried the onboard sound, but no real difference, still those pops and crackles. Easytune was installed, but I've now removed it; the two latency checkers are showing just the same results however. The DPC graph is very consistent, whith every third bar being a spike between around 1500us and 2500us.
08 Mar 2015   #4
Labrador
Home Premium 64
Scratch the last post. I hadn't rebooted at that point, but now I have and it's sorted! I'm amazed, how on earth does Easytune manage to make half a dozen drivers misbehave? The top 5 or 6 on Latencymon are all now 0.xx rather than the big figures on the chart in my first post, and DPC checker is a sea of green
08 Mar 2015   #5
fireberd
Yes, the EasyTune is working in the background and is a known cause. When I built my recording studio system and had the problem, one of the techs at a company that specializes in building recording studio PC's zeroed in on the EasyTune.
dvd movies no sound with dolby dvds on wmp...
why is there no sound for playing dvd movies using windows music player????? music concert dvds all play fine, as do CDs, internet sound. only movies have no sound. can't dolby and microsoft get to gether and allow dolby thx dvds to play using media player? downloaded this thing called AC3 filter...
No Sound when Playing DVDs in Media Player
Hey all, I've got full sound in everything else and the latest sound blaster drivers. I insert a DVD and play it in Windows Media Player or Center and I get no Audio (*shakes head). I play the DVD in VLC and it plays and sounds fine, but the Quality of the DVD video in VLC blows. What's the...
2 really annoying issues
one is that my icons for some things that are pinned to taskbar are disappearing, they still have icons in explorer but when i pin it goes to the missing icon symbol, the other issue is with winamp, i have win7shell installed but it doesnt work lol, i just get the regular winamp window when i hover...
Music, Pictures & Video
MC not playing DVDs Properly (sound issue)
I have a problem with my Windows 7 Media Center. When I try playing a DVD on it (does for only some DVDs), it plays the background music and the video, just the voices are gone. I made sure it wasn't just the movie by enabling closed captioning and using a regular DVD player. On the regular DVD...
Media Center
Annoying Keyboard issues
I installed Windows 7 last week. Ever since I am having issues of the calendar/clock window opening, the page randomly scrolling down, a window minimizing or the cursor disappearing whenever I am typing. It happens when I am typing in a search on the internet, typing in my blog, writing an email,...
General Discussion
Annoying issues with Folders
Just gotten windows 7 a few days back. I've found an annoying problem which started last night. When i try to open a nfew folder it opens a new windows as opposed to opening in the same window. I have the "Open each folder in the same window" option ticked. I have been installing a lot programs...
General Discussion
