Windows 7: Audio Device is disabled! Help?
08 Mar 2015   #1
neraknerak
Windows 7 Home Premium
i have a problem with my laptop. it says, "No speakers or headphones are plugged in" and when i clicked it says, "Audio Device is disabled". I tried checking on control panel but it says there that speakers and headphones are enabled. see attachments.
08 Mar 2015   #2
fireberd
Go to the Device Manager. Right click on the entry for the IDT Audio and then Left click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the Audio. This fixes most Windows/Audio corruptions and may fix your problem.
Audio Device is disabled/not installed
Hello, I'm new here and I have a problem I hope you all can help me with. OK, my audio was working fine until I decided to update the IDT High Definition audio driver. Bad mistake... Once I supposedly updated the audio driver, now my audio is not working and it has a red X on the speaker icon....
HDTV audio device disabled, then vanished
I've been streaming from my Acer Aspire laptop to an LG HDTV for a couple years. No problems with either video or audio. Once I plug an HDMI cord from the laptop to the TV, the laptop sound output defaults to the TV speakers after the laptop makes a two-note sound indicating connection. Three...
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
Audio device is disabled - no audio at all.
I'm on the verge of re-installing Windows. Spent the last 4 hours searching on here and other forums for a fix, but can't seem to find any. It started earlier today, I'd just installed Call of Duty: World at War off Steam, tried to launch it and it kept crashing. Tried a few things, but nothing...
How to identify disabled device in Device Manager
When I disable the network controller in Device Manager, the controller is disabled but nothing changes in Device Manager to identify the device as being disabled. When I used to do the same thing in Windows XP, the device icon turned yellow. Is there some setting to identify disabled devices...
Hardware & Devices
Audio Device Disabled (tried all normal approaches)
Hi there, well a while back my system (specs below) had a windows update when I went to bed, upon my return my PC booted up with no sound avaliable. i.e. in my task tray the speaker has a red X and displays "No Speakers or Headphones are plugged in" - they are definately plugged in. I did try to...
