Presonus Firepod (FP10) won't work completely in w7 pro
Hey,
I have a Presonus Firepod and latest 64-compatible drivers for it...and it works just fine in recording/audio programs, ASIO etc. and shows up in Windows just fine...
BUT windows won't play any audio through it other than via ASIO in the said programs. No system sounds, game sounds, nothing.
All the soundcard inputs and such show in Windows sound ctrl panel fine, look OK, no problems, BUT when I try to press 'test' or anything, it just reports that this hardware is being used by another application and please turn off the process first. It doesn't matter if it's set to default audio device or if there are other audio devices present.
Once I did all of a sudden manage to get it to sound, and it played via mediaplayer etc. just fine...but upon next boot, nothing. Again, used by another application.
Right now I've worked around the problem by using the internal Realtek card for windows/games sounds and just use headphones with them, but certainly it'd be easier to be able to use the presonus for also windows sounds, not only on audio programs, like it used to be in Xp.
