Windows 7: What type of cable is best to connect the audio reciever to the pc?
16 Mar 2015   #1
rammstein420
Windows 7 Home Premium 64bit.
Does it effect the quality? I have most of the hookups I believe.
16 Mar 2015   #2
society misfit
Windows 7 Professional
As per my other post, if your receiver has a HDMI input, I would go with that. HDMI has a much higher bandwidth compared to other digital interfaces thus allowing higher resolution audio. Toslink, or sometimes called SPDIF (or optical) does have limited bandwidth compared to HDMI - 24bit 96khz max. If you do not play media higher than that then you will be hard pressed to tell the difference between the two. However one benefit with Toslink is that it is not electrically conductive therefore it will not pass any electrical noise from the source nor will it pick up RF interference. So if you get a loud hum, usually referred to as a ground loop, when HDMI is connected you may want to try a Toslink connection.
As for the quality of the cable used in both configs?? I would stick with name brands that have lots of positive reviews from actual users and not just professional reviewers. They donít have to be expensive. Toslink is susceptible to breaking if bent too aggressively so keep this in mind should you be fishing the cable through a cabinet.
USB Type-C: One cable to connect them all
Found this article this morning and isn't this about time though it will throw a bit of a spanner in the works but common sense tells me at least it should have been like this since day 1 USB Type-C: One cable to connect them all - CNET
Hardware & Devices
Difference between Audio Cable and Aux Cable
Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well....
Connect TV to PC with a direct connect Cat5 Cable
I have a large screen TV that I need to run PowerPoint presentations on, and maybe video. The IT department set up Cat5 from the PC to the TV, but I cannot get anything from the PC to display. I am trying this on two different computers. One is XP Pro, and the other is Win7 Pro. I would prefer...
Graphic Cards
Printer cable advice - DB25 to USB Type B
Customer has an old accounting software package that is hard coded to print via the DB25 connector on his Desktop PC to a dot matrix printer which has given up the ghost. He does not want to replace the accounting package and so I am thinking I should be able to print from the DB25 port to his...
Hardware & Devices
Vaio cannot connect to N type wireless
Hey guys! I have a vaio EB2S1E and one router Linksys WRT120N. Both devices have the N wireless standard. When i set the router to Wireless N-only, my notebook cannot conect to it anymore, i see it as a device but after i enter the SSID it will not connect. If i leave it to Mixed or Wireless...
Network & Sharing
Connect 7 to XP via crossover cable
I'm trying to retrieve some files on my XP laptop from my 7 laptop and I have a crossover cable. I can't figure out how to do it. Do I have to create a domain or workgroup? thanks
Network & Sharing
