Windows 7: Front and Rear panel audio ports control
22 Mar 2015   #1
Rajike
Windows 7 Ultimate 32 Bit
hey guys,
i use a couple of speakers which is plugged to the rear speaker port, I'm using windows 8 pro atm and i cant access my front panel audio port to connect my hp, so can some one suggest me an app to control the audio ports which will allow me to plug my speakers and headphone and just to make 1 audio output,
reply fast thanks
22 Mar 2015   #2
Berton
That Motherboard number of G41d3b in your System Specs indicates a Biostar board [which should have been included]. Have you checked the maker's site for any software they might have that will do that?
G41D3B :: Motherboard :: BIOSTAR
22 Mar 2015   #3
Layback Bear
Windows 7 Pro. 64/SP-1
What does this mean from your post #1
Quote:
reply fast thanks
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Front USB ports not working, but rear USB ports work…
This is a brand new custom built PC for web browsing for a motel lobby. Win7 Home Premium AMD A4-3300 Llano MSI A55M-P33 FM1 Rosewill FBM-02 MicroATX Mini Tower Running latest BIOS and latest drivers downloaded directly from manufacturer's website. I tried switching between all 3...
Hardware & Devices
No Audio Output via Front and Rear Jacks
Hey guys, I installed the Hyper 212+ this weekend, but after installation, the audio stopped working. Thinking that this was a hardware issue, I went back and replugged some of the cables back into the mobo to make sure they were securely in there. No luck. My setup (other specs in profile):...
Help setting up AAFP for Legacy Audio 97 for my front panel ports
I have 2 USB's, a firewire & mix & line in & out ports on the front of my computer case. (Origen Case) I've had it setup before & know it needs to be setup as Legacy Audio 97. But I had to unplug it to remove my processor & I forgot that they were all separate plugs & I dont remember what goes...
Mic not working in front or rear panel.
Hey, my headset was working fine in Windows XP but ever since I upgraded to Windows 7 it hasn't worked, I've tried pretty much every setting in the Realtek command center, updating drivers and so on but nothing seems to work, all I can record is static noise :mad: Any chance someone can help me...
Front Panel USB Ports
Hello everyone. The USB Ports on the front panel of my desktop connect to my motherboard using a wire. Now thats all fine and dandy but I do not know which to plug it into. The pin layout for the following (which match with the USB's cord) is this. . . . . . . . . . Now I have 3 of...
Hardware & Devices
