Windows 7: Need analog audio out of my laptop. Cant use 2.5mm jack.
27 Mar 2015   #1
computergeekguy
7 home premium 64 bit
Hey Guys, Someone who I will leave nameless broke my 2.5mm audio jack on my laptop. At first I was bummed, then I purchased 7.1 usb gaming headset. I must admit they have the most pure sound I have ever heard. Bass is deep and treble is crisp.
I would be fine with this situation but I also have really nice sound system that is just sitting on my desk not doing anything. I used to rattle the walls but without my analog they stay silent. Is there anyway I can somehow get my digital outputs such as usb or HDMI to convert to analog? I don't have an HDMI stereo to use so I will need to build or buy a digital to analog for my usb/HDMI. I do have a broken HDMI cable so if one of the HDMI pins happens to be dedicated to analog audio I could cut and splice my own cable using my soldering gun. If HDMI is nothing but digital that would suck.
An suggestions to get my sound system up and running again?
27 Mar 2015   #2
fireberd
A USB connected "Sound Card" would be the best option. Price range for these vary from inexpensive to around $100. But, its the best option. Everything else would be digital and require a digital to analog converter (e.g. the USB connected sound card option).
Your USB connected headset does not use the PC's audio card (chip). It is digital and does the digital to analog conversion in the headset.
Look over the ones at newegg.com
usb sound card - Newegg.com
28 Mar 2015   #3
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Replace your motherboard
Realtek Audio not detecting analog inputs
I have a Gigabyte GA-P55-UD3R that has had no problem for quite a long time using Windows 7 64 bit. Recently after a reboot, the integrated Realtek audio no longer detects any analog connection (tried with mic/speakers/headphones) in any of the jacks. I removed the current drivers using add /...
Audio jack stuck in PC input jack...?
Hello my dear fellow windows 7 users! A few days ago, one half of the jack of my external speakers got stuck in the female jack of my PC laptop. I am using Realtek HD audio, and I wanted to ask whether it is possible for me to somehow disable the jack and have my audio played through my ...
Hardware & Devices
Hello my dear fellow windows 7 users! A few days ago, one half of the jack of my external speakers got stuck in the female jack of my PC laptop. I am using Realtek HD audio, and I wanted to ask whether it is possible for me to somehow disable the jack and have my audio played through my normal...
how do I switch micro jack to a audio jack
please help, My headfone jack (incorporated on the motherboard) is broken, and I bought a USB adaptor to conect my head fones, but it has a low quality. I came to know that it's possible to switch the microfone jack to use it has a audio jack, but I cant figure or research how. I use windows...
Can I Directly output audio from USB to 3.5mm jack?(My jack is broken)
Well my jack is broken since a few months so no joy for me... I hate it now when I can't listen to my music on my 14 speakers in my room. (NO KIDDING LOL) And today I was thinking about... HDMI... Audio?! Yes, but - I don't want to cut my only one hdmi cable which my parents use. So, I thought...
Left Channel Very Quiet with Analog Audio
Hey guys, I seem to be having an issue with my onboard sound card. It's a VIA card built into the Asus M4A785TD-M EVO motherboard. It seems to be that my left channel is roughly 20% of the volume of the right, even at 100%. The channel works because I can hear it, but it's not nearly as loud...
