Windows 7: RealTek hd audio manager subwoofer problem
04 Apr 2015   #11
society misfit
Windows 7 Professional
Jelled Fro,
You have determined the driver recognizes there is a Subwoofer channel with the test tone and everything is working as it should. The reason why this is not working for stereo music is because there is no information within that music file to tell the driver to send the low frequency information to the subwoofer channel. Stereo is only Left and Right channels. 2.1 is Left, Right and Low Frequency (otherwise knows a LFE). In order to have information sent to your subwoofer from a 2 channel stereo file, something needs to extract those lower frequencies and send it to the dedicated subwoofer channel. If the driver does not provide an option for this then you will need to look at a media player that provides this feature. Both JRiver and Foobar2000 media players have DSP modes that can be configured to take a 2 channel file, extract the lower frequencies and send it to the dedicated subwoofer channel. Perhaps you could share what media player you are using for music playback.
The single green connection that firebird is describing is not a true 2.1 configuration. It is a Stereo configuration where the full left and right frequency band is sent to the device via a single connection with crossovers built into the amplifiers that will separate the mids and highs from the low frequencies. Essentially it is 3 limited range speakers acting as 2 full range speakers (in simple terms). A true 2.1 relies on that .1 low frequency channel to be mixed separately from the left and right channels during mastering. TBH, there is not a lot of recorded material out there that caters to a true 2.1 configuration (5.1 and 7.1 is a different story). People rely on the DSPís within their receivers to separate that .1 LFE channel from the left and right channels.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD Audio Manager not there/problem with headset
Hi everybody, since this is the first time using sevenforums I will try to make it readable. So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
