Windows 7: RealTek hd audio manager subwoofer problem
02 Apr 2015   #1
Jelled Fro
Hi!
I'm new to the forum. I recently reinstalled my computer to start using my new ssd. Everything is working quite well except I can't get any programs to play audio through my subwoofer. It worked before the reinstall so I know its compatible. I use realtek hd audio manager and have two front speakers and a sub connected in the 5.1 configuration and the rest of the devices "unchecked". I had to use the center-output and the swap center-sub option to get any sound from the sub in the "auto test". There is a tone from the sub and from the front speakers, but there is no sub when I try to play music for example. And if i check the subwoofer in addition to the center the front speaker-sound becomes a little darker, so I don't know if the manager is confused about the outputs or if there is something else going on. I have a MSI Z77A-G45 and downloaded the latest audiodriver when I reinstalled.
02 Apr 2015   #2
fireberd
Two speakers and a bass speaker (sub) is a 2.1 configuration. With a 2.1 configuration, one connection is made to the GREEN speaker jack on the PC and everything is distributed in the 2.1 speaker system bass speaker which has the amplifier.
Any other configuration of two speakers and bass may or may not work.
02 Apr 2015   #3
Jelled Fro
There isn't a 2.1 option in the audio manager that I can see. Only sterio, quadraphonic, 5.1 and 7.1. Before the reinstall I belive I set the 5.1 option and then "unchecked" the speakers I didn't have. I'll attach the screenshots that I forgot in the last post to make the layout clearer.
02 Apr 2015   #4
fireberd
Stereo is what is used for a 2.1 system.
02 Apr 2015   #5
Jelled Fro
But then the sub doesn't show up at all. Nor does it play any sound.
02 Apr 2015   #6
fireberd
A regular 2.1 speaker system - two speakers and a sub - are connected with one cable ONLY from the Green speaker jack to the sub speaker. The sub speaker contains the amplifiers and distribution of the sound to the bass speaker and to the two speakers.
I don't think what you want to do will work correctly.
02 Apr 2015   #7
Jelled Fro
I have one cabel for the two front speakers and one for the sub. It worked before, I'm trying to figure out how to make it work again.
02 Apr 2015   #8
Jelled Fro
With the initial setup I can apparently get the sub to make sounds by checking the "rear pair" box. It seems too me if I could just get the maneger to recognize the sub as a sub, it should work like before.
02 Apr 2015   #9
fireberd
On a 5.1 system, there are three connections, but they are all to the bass cabinet and internally in the bass cabinet the sound is routed to the correct speaker.
You can select 5.1 then connect the two speakers to the Green jack and then try the Orange or the Black and see if that works.
Realistically consider getting a 2.1 speaker system.
02 Apr 2015   #10
HammerHead
win 7 X64 Ultimate SP1
Another Possible
Just today I loaded a multimedia app and it bricked my sound drivers (Realtek). I had to go get the latest drivers and reload it Realtek. So you might try reloading your sound drivers. Firebirds advice is sound (no pun) advice. Be really careful where you download the drivers from there is a multitude of sights that is offering adware/malware with the drivers. The name of the file is 0001-64bit_Win7_Win8.1_R275.exe. The driver date is 8/17/2012 and the ver is 6.0.1.6699.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD Audio Manager not there/problem with headset
Hi everybody, since this is the first time using sevenforums I will try to make it readable. So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
