Windows 7: PC's Microphone will not hold setting
13 Apr 2015   #1
Tipiford
Windows 7 pro 64 bit with XP Mode
I can adjust the microphone volume in "Microphone Properties" and within ten-seconds or so, the volume jumps back to 0. Cannot speak with anyone on Google or Skype.
14 Apr 2015   #2
fireberd
No system specs so all we can do is talk generalities.
Have you reinstalled the sound driver?
14 Apr 2015   #3
Tipiford
Re-installed driver, issue resolved
14 Apr 2015   #4
fireberd
Ah.
16 Apr 2015   #5
Tipiford
Whoa, I spoke too soon, issue still there. System is Win7 Pro, 64 bit Qosmio, PC's built-in mic.
I need Help Setting up My Xbox one microphone on my pc.
When I go to look for it in my sounds it does not show up, even when I show disabled devices. Can some one help me?
Windows 7: Can't change setting System Properties > network ID setting
I am trying to add a refurbished HP system to my menagerie. It had Windows 7 Pro (64bit) installed when I got it. I went through the setup without any problems, created a user account for myself (Lewis), set the system name to TestPC and started installing and testing some software. Simple...
Network & Sharing
Will my PC hold this much ram?
Ok so Intel website says this Max Memory Size (dependent on memory type) 32 GBMemory Types DDR3-1066/1333# of Memory Channels 2Max Memory Bandwidth 21 GB/sECC Memory Supported No And ive currently got 2.0gb of ram (see specs) and went and bought some more ram 2x2gb DDR3-1600
Hardware & Devices
Built-in Webcam Microphone and Microphone Line-in Not Working
I have a Dell Vostro 1500, running 32-bit Windows 7. It came with Vista, but I upgraded to Windows 7 a couple months ago, which I think is causing the issues I'm experiencing. According to whoever I'm speaking with, the sound for the microphone built in to my webcam fades in and out and gets...
Hardware & Devices
Power setting does not hold
I've customized my power setting so that the monitor is set to turn off after 25 min of inactivity. It was working for a several days but just last week, I noticed that my monitor was not turning off as expected. When I looked in the power setting, the "Turn off the display" was set to NEVER. ...
General Discussion
Hold'Em
Has anyone tried copying the files of Hold'em from Vista Ultimate to 7 Ultimate ?
Gaming
