Windows 7: Sound stops playing after changing volume
18 Apr 2015   #11
fireberd
If you have the headset USB plugged in and try to use the PC speakers you have to change the default audio playback device from the headset to the "Speakers". It won't automatically switch with the headset plugged in.
Remove the headset USB adapter and just have the PC audio, make sure the Speakers are set as the default playback device (and the Stereo Mix as the default recording device) and start from there. Does this work?
The volume bar shows sound but no sound through speakers.
Hi, I am pretty stumped with this one. I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues. When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Sound stops when changing audio input problem
Hello, I have a standard 3.5mm output jack on the back of my motherboard, whenever I change the jack, e.g. take speakers out, plug headphones in, the sound stops, usually when i'm using itunes, or bbc iplayer. Sometimes this can crash microsoft messenger as well. I have to restart the...
Distort Sound While Changing Volume
Hi everybody this would be my very first post =) And i start with a problem =( I made a Clean install of windows 7 (7600) on my laptop (my laptop is a Presario Cq40- 505la, link below (model and drivers) ...
Changing volume in game
hello everyone. Does anyone know of a way to change the system volume in windows 7 while your playing a game, without exiting? its a bit frustrating and i don't want to buy a new keyboard with volume controls.
Gaming
Sound volume level's changing?
Driver version Realtek HD 2.23 drivers. When ever I go in the options settings of garrys mod it resets my speaker volume and garrys mod volume to 10% any idea why it would be doing this?
