Windows 7: Sound stops playing after changing volume
16 Apr 2015   #1
SnyperBunny
Windows 7 x64
Hi everyone, I have a rather odd problem...
My sounds works fine, then as soon as I change the volume (either through the icon in my taskbar, through the volume control on a youtube video, or by the volume wheel on my headset), my sound crashes. It always makes my youtube vids throw an error and then stop making sound.
Anyone have any ideas on what could be causing this and how to fix it?
I thought it was a driver issue and deleted all the ones relating to sound. Once they reinstalled on reboot my sound was working fine and volume changing with no problem... then it stopped working and reinstalling the drivers isnt helping this time
16 Apr 2015   #2
fireberd
Youtube uses the Flash player (or HTML5). The flash player is known for sound problems. Reinstall the flash player and see if that helps.
16 Apr 2015   #3
SnyperBunny
Windows 7 x64
mmm... I probably didnt make this clear - it affects skype, windows media player and other vid playing websites too. Basically anything that makes sound on my computer stops making sound
16 Apr 2015   #4
fireberd
Oh, OK. Then the first thing is the sound driver. Do you have the correct sound driver or just the generic, basic function, Windows installed High Definition Audio Driver?
I used to have a Gigabyte motherboard, similar to yours - Z77X UD5H but too many problems and I dumped it as I had a spare Z77 motherboard (ASRock). I assume you have RealTek sound, you can download the latest R2.75 version directly from RealTek (its what I used with my Gigabyte). See how that acts.
Also temporarily disable applications that use sound, such as Skype, and see how it acts with just the application you are using with sound, such as the WMP.
Realtek R2.75 download site
The Realtek site seems to be down right now, but you can access it at www.realtek.com
A snowbird friend from Canada (Nova Scotia) just left this morning. He's heading to Toronto first then to his home near Halifax.
16 Apr 2015   #5
SnyperBunny
Windows 7 x64
I deleted my drivers and windows just auto-downloads them again...
The sound drivers listed are:
Corsair Vengeance 2100 Headset
NVIDIA High Def Audio
VIA High Def Audio
If I download the RealTek, how do I stop windows reinstalling the bad drivers?
Oh, and a reboot sometimes fixes the issue for a while :/
16 Apr 2015   #6
fireberd
If you have VIA, DO NOT install Realek. I just assumed since you had a similar Gigabyte motherboard that it had the same as mine. Sorry.
The Corsiar Vengeance headset is a wireless USB connected. USB audio device such as headsets DO NOT use the PC sound card. They get digital data from the PC and convert it to analog audio in the headset.
This changes the problem.
Are you only using the headset? and not PC speakers?
16 Apr 2015   #7
SnyperBunny
Windows 7 x64
just my headset. hmm... I'll check if the problem continues when I use speakers
of course now that I'm planning on trying another diagnostic thing it works <.<
17 Apr 2015   #8
SnyperBunny
Windows 7 x64
It broke again...
Speakers do not work (youtube and windows media player)
Headset does not work ( " ")
for some reason the little headset jack on the front of my comp near the power button still works (youtube and WMP)...
17 Apr 2015   #9
fireberd
The little headset jack is for the PC sound card and is analog. Not digital from the PC like the USB headset you have.
17 Apr 2015   #10
SnyperBunny
Windows 7 x64
my speakers also plug into a jack on the back of my comp though and they were not working either...
The volume bar shows sound but no sound through speakers.
Hi, I am pretty stumped with this one. I upgraded my office to windows 7 32bit pro. 10 computers all the same, but one of them has audio issues. When I play the sample music the volume bar shows the equalizer bouncing like it is sending out audio, but any speakers I plug into it produce no...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Sound stops when changing audio input problem
Hello, I have a standard 3.5mm output jack on the back of my motherboard, whenever I change the jack, e.g. take speakers out, plug headphones in, the sound stops, usually when i'm using itunes, or bbc iplayer. Sometimes this can crash microsoft messenger as well. I have to restart the...
Distort Sound While Changing Volume
Hi everybody this would be my very first post =) And i start with a problem =( I made a Clean install of windows 7 (7600) on my laptop (my laptop is a Presario Cq40- 505la, link below (model and drivers) ...
Changing volume in game
hello everyone. Does anyone know of a way to change the system volume in windows 7 while your playing a game, without exiting? its a bit frustrating and i don't want to buy a new keyboard with volume controls.
Gaming
Sound volume level's changing?
Driver version Realtek HD 2.23 drivers. When ever I go in the options settings of garrys mod it resets my speaker volume and garrys mod volume to 10% any idea why it would be doing this?
