Multiple Monitor prob and audio prob as well
  1. Posts : 1
    Windows 7 Ultimate
    Hey All
    First post here, I did a search and did not find any specific answer to my problem. Firstly I am running Win 7 Ultimate with an Nvidia 8600 GT video card running HDMI through the SPDIF output to the graphics card.
    My problem is getting my pc to duplicate to my HDTV when I hit the windows+p shortcut and select the duplicate option everything goes OK and I get pics on both monitors. The problem is that my PC changes resolution and slightly distorts. By distorts I mean circles look like eggs but HDTV is fine.
    My monitor is set to 1920x1280. I have the latest drivers installed and have re-installed them twice to be sure. I get them same error using the Nvidia Control panel, when running XP I had no problems at all doing this and running the correct resolution on both outputs.
    The other problem is when using VLC I get audio out to the HDTV no problem but when I try and use Windows Media center or player I get no sound at all.
    Any help would be great,
  2. Posts : 290
    Windows 7 Ultimate 64Bit (SP 1)
    FatsWaler said:
    Hey All
    Have you run media setup when using your TV? This should set the resolution and the sound up for you.
    Regards
    UKMedia
  3. Posts : 1,360
    win7 ultimate / virtual box
    using my 9800gtx+ I need to pick which output I'm using either "speakers" or "Spdif" and my audio works regardless but as far as the resolutions concerned I have had to tweak settings in the NVidia panel and the windows res screen and set my TV to scan only so that my resolutions dont corrupt in duplicate mode
