I am having a sound card issue
  1. Posts : 326
    windows 7 home 32 bit, I just changed back from 64 to 32bit
    1st off my os is Win7 Home 32bit. I just reinstalled the YouTube downloader from my backup cd after the last C drive partition wipe. Everything has been reinstalled clean including the os. Windows is working just fine except for when I download a YouTube video with the downloader. The downloader doesn't record a peep of sound from any video I have tried. When I play the video on Firefox the sound is fine. I have an other video capture prog "Replay Video Capture" that normally can capture both video and sound from any source playing on the internet or a local player on the laptop. Replay isn't capturing the audio eather. Also Replay Has on it's panel 2 vertical bars to show audio gain, The bars are flat line during recording. I also have an audio only capture prog called "Moo0 Voice Recorder" that will capture the YouTube audio just fine (Moo0 has a horz type audio display on the panel). The other 2 won't record a peep. I also tried a cold reboot (pulling the ac cord from the laptop and removed the battery). Still no change. I have never had this problem before with YouTube downloader or Replay Video Capture. I have been using both prog's for a long time without any problems. I can't figure out why those 2 capture prog's won't record a peep. I also tried del and reinstalling both prog's. That didn't help eather.
    This is really not a "sound" issue, and more an application (program) issue. Your sound apparently works except with certain programs.
    I would post this on a different forum section that deals with programs.
  3. Posts : 199
    Windows 7 Pro x64 sp1
    YouTube etc often take steps to protect their content ie block downloading. Anyhow, I think this topic goes against forum rules -
    4) No piracy or discussion of piracy allowed at all. Such as software, music, videos and other intellectual property violations (e.g. downloading youtube videos locally etc).
    > don't shoot the messenger
  4. Posts : 326
    Badcrc it is not piracy to download from YouTube. YouTube gives away FREE "no strangs attached" the YouTube downloader. Just d/l the YouTube downloader from a YouTube sponsored web page or you will end up with garbage that you don't want or need attached to the YouTube downloader when you d/l from those non-sponsored web pages. By the way YouTube makes it's money from the commercial-business pages on YouTube. Like KNDU tv 25. And so on.
    And bang to the messenger
    Steve
  5. Posts : 18
    win 7 64 bit
    c lean your pc first
  6. Posts : 326
    Fireberd I found the problem. I have a prog installed called "VAC=Virtual Audio Cable". For those that don't know. (this is not ment as advertising for VAC) Virtual Audio Cable software allows you to transfer audio (wave) streams between applications and/or devices. It creates a set of virtual audio devices named "Virtual Cables", each of them consists of a pair of the waveform input/output devices. Any application can send audio stream to an output side of a cable, and any other application can receive this stream from an input side. All transfers are made digitally, providing no sound quality loss.
    I use VAC for digital transmitting on the HF Amateur Radio bands. I do all my HF transmitting via an internet controlled remote base. I live in an apt. No outside antennas period other then Dish Network or Direct tv. Without VAC I need 2 laptops to transmit digital. The digital decoding software (via the sound card) won't talk to the remote base prog on the same laptop without the VAC prog. I didn't know I had to redirect Firefox audio to the YouTube downloader or the Real Video Capture prog in order to get the sound with the video. Call it a lesson if someone else has VAC loaded up and has a similar problem.
  7. Posts : 199
    I was just pointing out forums rules - rule #4 says no discussing of YouTube downloading.
    Quote from YouTube terms + conditions
    you agree not to access Content or any reason other than your personal, non-commercial use solely as intended through and permitted by the normal functionality of the Service, and solely for Streaming. "Streaming" means a contemporaneous digital transmission of the material by YouTube via the Internet to a user operated Internet enabled device in such a manner that the data is intended for real-time viewing and not intended to be downloaded (either permanently or temporarily), copied, stored, or redistributed by the user.
    https://www.youtube.com/static?gl=GB&template=terms
