I am having a sound card issue
1st off my os is Win7 Home 32bit. I just reinstalled the YouTube downloader from my backup cd after the last C drive partition wipe. Everything has been reinstalled clean including the os. Windows is working just fine except for when I download a YouTube video with the downloader. The downloader doesn't record a peep of sound from any video I have tried. When I play the video on Firefox the sound is fine. I have an other video capture prog "Replay Video Capture" that normally can capture both video and sound from any source playing on the internet or a local player on the laptop. Replay isn't capturing the audio eather. Also Replay Has on it's panel 2 vertical bars to show audio gain, The bars are flat line during recording. I also have an audio only capture prog called "Moo0 Voice Recorder" that will capture the YouTube audio just fine (Moo0 has a horz type audio display on the panel). The other 2 won't record a peep. I also tried a cold reboot (pulling the ac cord from the laptop and removed the battery). Still no change. I have never had this problem before with YouTube downloader or Replay Video Capture. I have been using both prog's for a long time without any problems. I can't figure out why those 2 capture prog's won't record a peep. I also tried del and reinstalling both prog's. That didn't help eather.
