Hello, I have a Toshiba satellite running windows 7 home premium (64 bit).
For quite a while I've had an issue where my sound would randomly cut out.
I recently discovered (after much trial and error) that the cause of the issue is that my computer is detecting something plugged into the...
When I connect my headphones to ipad or any other devices, It works fine but when I connect it to my PC at rear green port it gives me low volume and mic doesn't worked and recognised too.
I got ports at rear of my cabinet only.
Please give me solutions.
Have Hp laptop with win7, it came with beats audio installed. I had to have the hard drive replaced
an now I have lost Beats audio. Is there a way to get it back. The so called free down loads add
Things to the computer that you can't get rid of. The shop that replaced the hard drive
Is closed
Title says it all while listening to music the volume constantly swings in and out. This is a commin problem among the hp laptops with beats audio. I have the most updated audio driver out at the moment. Ive tried what they have posted and for some i dont have the options for. Just looking for...
I recently bought HP dv6-6102sa laptop which comes with beats audio. Does anyone know if I have to do some settings to make sound better or it will only work with beats headsets. I've tried normal headsets and I didn't noticed any difference sound quality.
Also in quick guide, it says laptop got...
