Windows 7: Plantronics Audio .326 Headset not working on Inspiron 1525 Mic Jack
30 Apr 2015   #1
Alpha Hedge
I recently bought a Plantronics headset, and plugged it in my microphone jack. It says "Line IN" when I try to use it with audacity, but when I record, and even yell into it, nothing shows up on the line. My laptop has 2 headphone jacks and a mic jack. Could this be the problem?
01 May 2015   #2
fireberd
If you have plugged the microphone part of the headset into the "Mic" jack on the PC and using the "line in" to listen that is incorrect. Generally, Audacity uses the "Stereo Mix" to record. With Stereo Mix set as the default recording device any input is "heard".
Second, if you are plugging the mic into the "line In", that is incorrect and the mic will never work. A computer mic needs +5V DC to operate. The Mic in jack has the 5V, a line in does not and is a stereo (2 channel) input.
You list a Dell Desktop in your System Specs but are referring to a Dell Inspiron 1524 "Laptop". ???
01 May 2015   #3
Alpha Hedge
I don't have stereo mix. all it shows is "Microphone" (the internal mic) and "Line In" (I'm guessing that's my headset.) I don't know what the heck's going on!
Oh! I'm very sorry, I must have not payed attention to that, my apologies, I just fixed it.
02 May 2015   #4
fireberd
If Stereo Mix is not showing (its on MOST PC's), go to the Sound/Recording section and RIGHT click in a blank area in that panel. Click to show Disabled and Disconnected devices. Stereo Mix should show up and you can enable it and make it the default recording device.
I don't know if that will fix the problem, but its a first step.
02 May 2015   #5
Alpha Hedge
The Stereo mix is not showing when I enable disconnected and disabled devices. This is what it looks like.
Plantronics Audio .326 Headset not working on Inspiron 1525 Mic Jack-recodi.png
02 May 2015   #6
fireberd
You only have the generic, basic function, Windows installed High Definition Audio Drivers. I looked at the Dell site and the only drivers listed are Sigmatel drivers for Windows XP. There are no Vista/Win 7 drivers as Dell does not support anything other than XP on this model.
Does the internal mic work? If it does, make sure you are connecting the microphone part of the headset to the mic jack.
02 May 2015   #7
Alpha Hedge
I found out my own solution. What I DID was I installed the sigmatel audio driver R218148 and it installed it itself.
Plantronics Audio 355 MIC not working?
So i just bought a Plantronics Audio 355 From EbGames IN AUS So the problem is that i can hear sounds properly but when i use a program like Action record my voice, i can't hear my voice but i can hear a LOUD buzzing noise. HOW do i fix this, AND I KNOW its not muted.
Hardware & Devices
Headset Mic Jack not working
A few hours my headset mic stopped working on my computer and stopped picking up sound from me. It wasn't the mic's problem as it worked on another pc but not mine and was not working with Skype or any recording program. I have uninstalled the ITD Driver, loaded defaults, enabled the device and...
Audio jack not working properly
Since yesterday my laptop has been doing something very weird. I can't get any audio through the headphone jack. The laptop's speakers work fine. When I plug in the headphones then the sound continues to come out of the speakers. When I check the sound devices it shows that the headphones are...
Rear audio jack not working properly
I got a brand new computer. Motherboard is a Gigabyte GA-78LMT-S2P. Operating system is Windows 7 Professional 32-bit. Brought it home, it installed a .net update and restarted and since then, I've had the infamous RealTek pop-up problem. Keeps telling me something is plugged in then unplugged...
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
Problem with Sigmatel Audio Driver for Inspiron 1525
Hi I have an Inspiron 1525 running on Windows 7 Ultimate. I have been facing an issue with my Sigmatel Audio Driver for windows 7. I tried re-installing the drivers many times but problem still exists. The issue is that sometimes when a sound event occurs, may its the 'exclamation' sound or...
