Windows 7: How to connect PC's sound with LED monitor's speaker
07 May 2015   #1
Binish Joshi
Windows 7 Ultimate 32bit
My Speaker have been damaged for months. The audio comes buzzing tune. So. want the Pc's audio come from my LED Monitor that supports "USB" , ""ATV" , "AV" , "Component" , "HDMI" , "PC" and "USB".
I want you guys to help me to take me out of this problem.
Hope you'll.!!
07 May 2015   #2
fireberd
If your monitor is HDMI and supports HDMI sound, that is the only way I see, based on what you have reported. Otherwise, the monitor must have a 3.5mm jack for audio input and then you can connect a cable from the 3.5mm Speaker (Green) jack on the PC to the monitor.
07 May 2015   #3
Binish Joshi
How to know that my computer supports HDMI sound or not??
Please reply.
07 May 2015   #4
fireberd
Based on your listed specs, the PC does not support HDMI.
If the monitor does not have a 3.5mm jack for audio input you will not be able to use the speakers in the monitor.
07 May 2015   #5
Binish Joshi
"Based on your listed specs" what does this mean
Can I use Speakers jack for monitor which has green jack at one end and red and white at another
07 May 2015   #6
carwiz
Windows 7 Pro-x64
No one here can see your display or PC connections so we rely on the information YOU supply in your system specs. That's why it's important to supply exact make and model numbers so that someone can look them up to verify the available connections and make recommendations.
07 May 2015   #7
Binish Joshi
I don't really understand what are you trying to tell, carwiz ..
08 May 2015   #8
RoasterMen
Windows 10 Pro 64-bit
If your monitor has built-in speakers, check for the speaker port (Usually it's colored green) or just use the HDMI Port
08 May 2015   #9
fireberd
He apparently does not have a HDMI port on the PC, again based on his listed specs. His PC only has 1.5GB of Memory and the video card has 256Mb. This suggests a very old PC.
We are only guessing as not enough information on his PC and monitor have been provided.
08 May 2015   #10
Binish Joshi
I added 0.5 GB of Ram myself wait, I again replaced my motherboard as it damaged by shutting down my PC by cutting of power Supply
I really bought this PC on 2008 really
I don't think my PC does support HDMI Port.
How to connect PC's sound with LED monitor's speaker-untitled.png   How to connect PC's sound with LED monitor's speaker-1.png
HP laptop no sound from speaker but there is sound through headphone
My wife HP Pavilion DV6175ea laptop running windows 7 ultimate 32 bits was fine with the sound until a month ago. Note that upgraded from vista since the windows 7 launch. From that date till now it as no sound from the speakers but it is ok from the headphones. Tried different audio drivers but...
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
speaker symbol appear in middle of monitor
A speaker symbol and a blue line appears in the middle of my monitor, and then goes away. I've tried clicking it, and nothing happens. Anyone have this problem, or know what it is? Thanks
Sound from monitor speaker, screen freezes for a second
First of all, I don't expect to find a solution to this problem, because it seems really weird to me. Recently, my monitor has been emitting a split second crackling/static like sound two or three times a day - I dunno. But when that happens, and I happen to be moving my mouse, it will freeze for a...
I have hp dv1738od and have upgraded to Windows 7, previously Windows XP. Everything seem to be working ok except, for the sound. Window 7 automatically installed the driver, and said the sound card was working properly. But there was no sound through speaker. I removed the driver and reinstall...
