Windows 7: Quadraphonic setting problems
19 May 2015   #1
GThrash
hi, i tried to connect 2 sets of speaker systems (one with just 2 speakers and a 2.1).
i inserted them on the green and black jack and applied the quadraphonic settings.
it works perfectly fine with AIMP3 but works with nothing else.
in browsers etc the sound comes only from the set of speakers plugged in the green jack.
how can i get them to work and is there any way to configure the way i want them to sound? eg to have 2 center speakers and 1 left, 1 right.
thanks in advance
19 May 2015   #2
fireberd
Surround sound is usually determined by the media program. I've seen several reports from users with surround systems that only the front speakers have audio.
Problems setting up RAID
First, I looked through the forum history and couldn't find my solution. If this has all ready been covered I apologize. I'm trying to set up raid 0 on a fresh install. When I go to install the drivers on setup I get the following error: "To continue installation, use the Load Driver option...
Hardware & Devices
Quadraphonic Sound with Realtek Drivers
I am trying to obtain quadraphonic sound using front and rear speakers attached to my motherboard. The four speakers work fine in the control panel, but I cannot get the rear speakers to work in any audio program. I want to get surround sound with separate audio files coming from each of the...
Problems setting up Network between Win 7 and Win 8 pcs
Hello, I am having problems creating a network between 2 computers. Win7 is running Windows 7 Pro 32 bit. Win8 is running Windows 8 Pro 64 bit. Both logged on as Administrator. Win7 can read and write to files on Win8.
Network & Sharing
Quadraphonic sound issue with Realtek HD audio
Hi. I have a problem with the quadraphonic sound in my computer. I've installed Windows 7 RC and the realtek HD audio drivers just yesterday, and when I configure the quadraphonic sound in the Realtek audio manager it seems to work fine. In the tests, the four speakers sound clear, but when I play...
Quickly switching between Stereo/Quadraphonic speakers
Hello everyone! My desktop has a basic integrated VIA HD audio chip. For output purposes, I have a pair of passably good headphones (suitable for music, films and games) as well as the integrated speakers in my LCD screen, which are awful but perfectly fine for podcasts, YouTube, alarm clocks,...
Can't set Quadraphonic (4) speaker with RealTek AC97
Windows Update installed the driver for me. The front speakers work fine. However if I use the RealTek applet or the Sounds applet in Control Panel, I cannot set it to use 4 speakers. When using the RealTek one, it just doesn't save the setting. Or it'll switch to the digital output (which I...
