Windows 7: Front audio ports in mono, not stereo
20 May 2015   #1
Nu2jirsa1
Win
Del
Del
20 May 2015   #2
fireberd
Have you considered the front panel jack is the problem rather than the motherboard? I had a new case with a defective front panel assembly. Corsair sent me a replacement front panel assembly and the problem(s) were fixed.
20 May 2015   #3
Nu2jirsa1
Win
Del
21 May 2015   #4
fireberd
I missed that, sorry. Looks like a motherboard problem, considering everything you have done.
Sounds constantly switches b/w mono and stereo on Internet videos
Hello! New member with an annoying problem. I got the latest updates from Microsoft last week and after that my internet sound has had problems. At first, it would quickly fade to almost nothing before coming back. It now switches from normal stereo (set at 24 bits, 48000 Hz) to softer mono for...
Front and Rear panel audio ports control
hey guys, i use a couple of speakers which is plugged to the rear speaker port, I'm using windows 8 pro atm and i cant access my front panel audio port to connect my hp, so can some one suggest me an app to control the audio ports which will allow me to plug my speakers and headphone and just to...
Stereo Audio Output Inverted on Realtek Front Panel and Firewire Card
Hi, I just realized that stereo output is inverted (L&R are swapped) on my Realtek front panel headphones connector and on my M-Audio Firewire card. Output is OK on Realtek rear main/front speakers connector. Any ideas on how to fix this? Thanks, J
Front audio headphone jack reversed stereo...
I have a Gigabyte GA-P55-UD5 motherboard with on-board sound by Realtek, and my case is Thermaltake's "Element G". I connected the front panel audio cable to the designated connection on the motherboard, however, whenever I plug-in my headphones, the stereo is reversed! Meaning that the...
Help setting up AAFP for Legacy Audio 97 for my front panel ports
I have 2 USB's, a firewire & mix & line in & out ports on the front of my computer case. (Origen Case) I've had it setup before & know it needs to be setup as Legacy Audio 97. But I had to unplug it to remove my processor & I forgot that they were all separate plugs & I dont remember what goes...
No Stereo Mix or Mono Mix in Windows 7 64-bit
I had it in 32 bit RC.. Any ideas? Here's photo http://img690.imageshack.us/img690/6199/rec.jpg
