Windows 7: No sound in back audio panel jack - Realtek HD Audio Manager
25 May 2015   #1
Milos Master
Windows 7 Ultimate 64 bit
Hello,
I have Windows 7 Ultimate 64 bit and I have a problem with sound. When I plug my speakers in front panel I have output audio, but in back panel I don't.
My Audio Manager looks like this, but front panel is enabled and back panel is disabled. It does not recognize back (ANALOG) jack.
I tried with settings in this manager but without success, I cheked Control Panel > Sound and followed instructions but still no sound if speakers is in back panel. What to do?
P.S
Sorry for bad english
25 May 2015   #2
fireberd
What is set as the Default Playback Device? If "Digital" or "HDMI" is set as default you will not get any sound from rear audio connections. "Speaker" must be set as Default Playback Device/
25 May 2015   #3
Milos Master
Where is that option?
25 May 2015   #4
fireberd
Go to Control Panel/Hardware and Sound and finally the Sound Playback panel.
26 May 2015   #5
Milos Master
Default device is Speakers, but they only works in front panel...
26 May 2015   #6
fireberd
You show a 5.1 speaker system selection. Do you actually have a 5.1 system with 3 connections?
26 May 2015   #7
Milos Master
This is not picture of my Audio Manager, but mine is this version too.
26 May 2015   #8
fireberd
Please post a picture of the system that has the problem, so we can try to troubleshoot the correct system.
Also the system specs.
10 Aug 2016   #9
toby1
I am having exactly the same problem for several months now and I can't find the solution no matter what. I used to be able to switch between the headphones which I have connected to the front panel jack and the speakers in the back through the Realtek Sound Manager, but suddenly the back panel jack simply stopped transmitting any sound signal at all. The front jack keeps working fine though and the speakers themselves are perfectly operational as well.
I tried to deactivate/reactivate the speakers from Control Panel > Sound and I even uninstalled/reinstalled the audio driver but with no luck.
Win7 Ultimate x64
Motherboard: ASUS H97M Plus
NVIDIA High Definition Audio 1.3.26.4
Audio Driver: RTKVD64.sys
Thanks a lot for your time
Realtek HD Audio Manager not in Control Panel
Hi everyone, I've just installed the latest Realtek driver and the installation goes fine but Realtek HD Audio Manager won't appear in the Control Panel or the System Tray (however, when I go to customize the notification icons, Realtek HD Audio Manager appears as "Show icon and notifications")....
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
NO SOUND and my Realtek HD Audio will not open from the control panel
Windows 7 86. I have NO SOUND and my Realtek HD Audio will not open from the control panel. I have reinstalled the drivers and used system image to recover but it has not solved the problem. I have used this system image before and it work perfect. I think it is a hardware problem but how can I...
Difficulty with 5.1 sound, Realtek HD Audio Manager
I am posting because I am having trouble getting my 5.1 system to work with my Acer Aspire 7551 laptop the way I want it to. My laptop is connected to my receiver by HDMI, but Realtek HD Audio Manager only supports stereo sound. I have attached a screenshot. Sound only comes out of the front L and...
Realtek HD audio - Front jack makes cracking sound
MODS: I post this thread to isolate the most important problem from my previous thread and to make it clearer and easier to answer. I hope that's alright. I have this on onboard Realtek HD audio card. And no matter if I connect the AC'97 or HD audio adapter to the motherboard, the sound that...
