Windows 7: PC sound problems. No system sounds, no audio.
11 Jun 2015   #21
MistUnleashed
We'll do one more thing
Follow the instructions here: Blue Screen of Death (BSOD) Posting Instructions
I know your problem is not BSOD related but still follow the instructions to use the DM Collector
Zip up the file, if it doesn't do it for you, then post it to this thread so I can take a look.
11 Jun 2015   #22
Shoju
Windows 7 64 bit
Okay, here is the zip file.
File Type: zip DEVANTIER-PC-Thu_06_11_2015__90031_25.zip (1.28 MB, 1 views)
11 Jun 2015   #23
MistUnleashed
Quote   Quote: Originally Posted by Shoju View Post
I've noticed a problem straight away. You have 4x Anti-Virus Software installed on your PC, there is a high chance that they are conflicting in some way. Please remove Avira, Spybot and McAfee and leave MSE.
After this run a full scan using Malwarebytes: https://www.malwarebytes.org/
Post screenshots of any viruses found - Also remove the viruses from the system.
I will report back when i've gone through the rest of what you have uploaded.
11 Jun 2015   #24
Shoju
Windows 7 64 bit
Okay, McAfee, Avira and Spybot are gone and the Malwarebytes scan is running.
11 Jun 2015   #25
MistUnleashed
Thanks, post up the results when it completes.
11 Jun 2015   #26
Shoju
Windows 7 64 bit
Okay, the results of the scan were:
11 Jun 2015   #27
MistUnleashed
Thanks, now follow these steps:
  1. Go to: Device Manager
  2. Find your on-board soundcard driver
  3. Uninstall it
  4. Restart PC
This will see if the generic windows drivers are working.
11 Jun 2015   #28
Shoju
Windows 7 64 bit
I still have MWB open. I didn't want to touch anything until you posted. Should I 'fix' the PUPs or just leave them for now?
11 Jun 2015   #29
MistUnleashed
Delete them if you can, else just 'Fix' them
11 Jun 2015   #30
Shoju
Windows 7 64 bit
Okay, onboard sound isn't showing in the Device Manager, most probably due to in an earlier post Fireberd had me disable it in the BIOS. Do you want me to 're-enable' it and then uninstall the drivers?
No Sound or System Sounds working
Long story short. Just recently I have not been able to get sound on my computer (All In One Desktop). Neither sound nor system sounds. I believe it started when I started plugging in my earphones into the jack. I can hear sounds (movies, video) and I can also hear the system sounds. When I...
No sound from internet, but have system sounds
I'm working on a rebuild of an old Dell. I disabled the onboard sound, and installed several different PCI sound cards. The system is not my main system, but a spare. It's a 32-bit processor, but has Win7 Pro 64 OS. The onboard sound adapter is so old, I could not get 64-bit drivers from Dell,...
Sound card sounds no better than integrated motherboard audio?
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the...
Recording Audio/ mic and system sounds...with headphones?
I have a screen recorder that records my screen and also my mic at the same time, i make videos to help with my knowledge base articles in sharepoint. I need to record my mic/ and also system sounds like if i have someone on skype and i am screen recording, i need to be able to record there audio,...
Laptop will play system sounds but no other audio!
Hi, I recently upgraded to windows 7 (from vista) on my HP Pavillion dv9000 series (specifically dv9850ea) Beforehand when I ran the upgrade advisor, I got a few warning about incompatabilities - the graphics card for example - but all seems fine after the upgrade. My problem is with the...
