Windows 7: PC sound problems. No system sounds, no audio.
13 Jun 2015   #41
MistUnleashed
Quote   Quote: Originally Posted by Shoju View Post
@gregrocker and BorisThe Animal
The Troubleshooter and diagnostics have both come up with nothing. That hardware is all up and running fine, but there is no audio. As I mentioned in the OP, I did a install of my OS on a small partition and the audio is working fine. So think it might be time for a drive format and a clean install.
I would like to thank everyone for their help with this.
No worries, let us know if you need any more help!
13 Jun 2015   #42
gregrocker
You can delete the old OS and expand the new one into the space. Post back a screenshot of Disk Management - Post a Screen Capture Image and we will give you the steps.
13 Jun 2015   #43
BorisTheAnimal
Windows 7 Home Premium
Damn well hopefully you will get it sorted out!
And no problem we are all here to help each other!
13 Jun 2015   #44
Shoju
Windows 7 64 bit
Okay, here is a screenshot of the Disk Management page.
13 Jun 2015   #45
MistUnleashed
Where's the partition with the second Windows OS on it?
14 Jun 2015   #46
ICIT2LOL
Just backing up a little re the sound I see you have Asus Xonar speakers and for the cost of the card why not swap out the THX TruStudio one for an Asus Xonar DG?? I have them in all my desktops and never a problem.
Depending on where you live of course the cost of these are minimal and the GUI for mixing and effects are something else. (I paid $35 for my cards) https://www.asus.com/au/Sound_Cards/Xonar_DG/
Plus I drive 5:1 Logitec Z506 systems from mine and couldn't be happier.
No Sound or System Sounds working
Long story short. Just recently I have not been able to get sound on my computer (All In One Desktop). Neither sound nor system sounds. I believe it started when I started plugging in my earphones into the jack. I can hear sounds (movies, video) and I can also hear the system sounds. When I...
No sound from internet, but have system sounds
I'm working on a rebuild of an old Dell. I disabled the onboard sound, and installed several different PCI sound cards. The system is not my main system, but a spare. It's a 32-bit processor, but has Win7 Pro 64 OS. The onboard sound adapter is so old, I could not get 64-bit drivers from Dell,...
Sound card sounds no better than integrated motherboard audio?
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the...
Recording Audio/ mic and system sounds...with headphones?
I have a screen recorder that records my screen and also my mic at the same time, i make videos to help with my knowledge base articles in sharepoint. I need to record my mic/ and also system sounds like if i have someone on skype and i am screen recording, i need to be able to record there audio,...
Laptop will play system sounds but no other audio!
Hi, I recently upgraded to windows 7 (from vista) on my HP Pavillion dv9000 series (specifically dv9850ea) Beforehand when I ran the upgrade advisor, I got a few warning about incompatabilities - the graphics card for example - but all seems fine after the upgrade. My problem is with the...
