PC sound problems. No system sounds, no audio.
Page 5 of 5 FirstFirst ... 345
  1. Posts : 260
    Shoju said:
    @gregrocker and BorisThe Animal
    The Troubleshooter and diagnostics have both come up with nothing. That hardware is all up and running fine, but there is no audio. As I mentioned in the OP, I did a install of my OS on a small partition and the audio is working fine. So think it might be time for a drive format and a clean install.
    I would like to thank everyone for their help with this.
    No worries, let us know if you need any more help!
    You can delete the old OS and expand the new one into the space. Post back a screenshot of Disk Management - Post a Screen Capture Image and we will give you the steps.
  3. Posts : 1,436
    Windows 7 Home Premium
       #43
    Damn well hopefully you will get it sorted out!
    And no problem we are all here to help each other!
  4. Posts : 20
    Windows 7 64 bit
       #44
    Okay, here is a screenshot of the Disk Management page.
    Attached Thumbnails Attached Thumbnails PC sound problems.  No system sounds, no audio.-management.png
  5. Posts : 260
    Where's the partition with the second Windows OS on it?
  6. Posts : 21,004
       #46
    Just backing up a little re the sound I see you have Asus Xonar speakers and for the cost of the card why not swap out the THX TruStudio one for an Asus Xonar DG?? I have them in all my desktops and never a problem.
    Depending on where you live of course the cost of these are minimal and the GUI for mixing and effects are something else. (I paid $35 for my cards) https://www.asus.com/au/Sound_Cards/Xonar_DG/
    Plus I drive 5:1 Logitec Z506 systems from mine and couldn't be happier.
