Windows 7: Microphone Volume is quiet, even at maximum volume
10 Jun 2015   #1
baaz
Windows 7 64 bit
So I recently moved my microphone/headset plugs to the rear jacks of my computer, the reason I did this was because when plugged in to the front jacks, my microphone had a white noise I couldn't get rid of, the rear jacks doesn't have this issue, but my mic volume is quiet
I think it might be a driver issue? I know its not my mic because when plugged in the front, people can hear my voice fine but there's just static noise too, and it's sort of loud
11 Jun 2015   #2
fireberd
More PC info is needed. Including what sound and sound driver you have.
The front panel jacks are just an extension of the sound jacks. Usually if there is problem, the front do not work correctly but the read does. Are you plugging the mic into the correct Pink jack? If it were plugged into the wrong jack that can happen.
11 Jun 2015   #3
baaz
Windows 7 64 bit
They are plugged into the right jacks at the back
What do you mean what sound/driver do I have? Like, what specifically are you asking for and how do I find it
11 Jun 2015   #4
fireberd
You can download and run the free Speccy. It will profile your PC. If this is a factory built PC, what is the Manufacturer and Model Number?
Speccy - System Information - Free Download
15 Jun 2015   #5
baaz
Windows 7 64 bit
Sorry for the late reply, my computer is custom built so that's why I think the issue could be a missing driver(s)
Would you still like my speccy information?
16 Jun 2015   #6
fireberd
Yes, having the system info - Please fill in the "My System Specs" helps us to try and help you.
Speaker & Microphone always set to maximum volume
My wife has Windows 7 and the speaker is always set to maximum volume. (The computer makes a loud, shrill noise all the time.) Now, it can be muted and that is what she is doing now. In addition, the problem does not exist in Safe Mode. I have no idea what process is causing this. (Is the only way...
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Realtek HD Audio volume is a little too quiet, Help in increasing nois
Well here's the story, I have a Custom PC with a i7 3770k And a AsROcK b75-pro-3m motherboard with Realtek HD audio, but for some odd reason the sound is not very good, it feels moderate at full blast, where as in comparison with my very old C2D fujitsu Lifebook T4215 tablet PC, which can play...
Microphone volume unusably quiet under Win 7.
I have a frustrating recording problem - volume through my microphone is unacceptably poor under Win 7. I'm using a mic which recorded superbly under XP Pro on my old set-up. It's now plugged in to my new PC (front mic) under Win 7, but even with input level full and boost at 30dB the...
Volume at MAXIMUM on startup
Hello all, first post here (of many probably, heh). Whenever I startup into W7 my volume is always at maximum, anyone else encountered this? I did a quick search but only founf issues related to low volume, 50% volume and sound card driver issues etc... I would love to here your thoughts on my...
