Windows 7: Annoying Echo Sound Every 40-60 Minutes?
11 Jun 2015   #1
grizzly77
64bit Windows 7
For the past few weeks now this annoying echoy sound will play through my speakers every so often numerous times a day. Is there any way to track down certain sounds? Has anybody had this issue?
11 Jun 2015   #2
fireberd
Hard to say with your limited information. But, I would suspect some open program, maybe in the Notification area, is causing it.
repeated echo loop sound on Windows 7
i am experiencing a repeated echo loop sound on my PC as i use Windows 7 and i don't know where else to look as i don't use a mic nor headset as i muted most of the sounds as i got 3 devices in Sounds speakers,Realtek Digital Output and Realtek Digital Output RCA i don't know on how they got in but...
Echo-y sound
On my new Windows 7 tower computer, when I plug in speakers or headphones, everything sounds like the bottom of a well. How can I get rid of that? (Realtek High Definition Audio) (Windows Home Premium SP 1) Thanks,
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
Sound has a little echo
My sound in Windows 7, windows media player, has a little echo. It's like my speakers are at the bottom of a well. Any idea on how to make the sound normal? I have the newest drivers installed. Thanks
Annoying sound problem
Hey everyone, I'm using Windows 7 x64 Ultimate and i have rather annoying sound problem. As I'm listening to the music in Winamp while playing some game, say Warcraft 3 (or doing anything that makes sound for that matter), everytime there's a fight (like 10 units bashing on eachother), Winamp...
ECHO echo sounds
Hi My only poroblem with RC7100 revolves around the fact that through my speakers, when playing music, I get an "echo-ey" sound....I thought it was because I had placed my microphone too close to the speakers and/or had my microphone turned up too loud (no such problem when set up the same when...
