Windows 7: headphone jack is not working right, I have to hold it to work
11 Jun 2015   #1
BasedDoge
windows 7
I have to hold it to one side for it to work right, is there a way to fix it?
11 Jun 2015   #2
matthewk
Windows 7 professional, 64 bit
Sounds like the jack is busted. That happens if you use them a lot. Any moment on the plug puts a lot of stress on the guts of the jack and on the little solder pads that hold it on the board. You might be able to reflow the solder joints if you feel like taking the notebook that far apart. Personally I would just buy an inexpensive USB sound dongle, under $4 from China, and be really careful of any jacks connected to the notebook moving forward.
12 Jun 2015   #3
BasedDoge
windows 7
I have to hold it up, but if I turn the plug 180 then I have to hold it down, why is that? You sure it's the jack?
12 Jun 2015   #4
fireberd
That sounds like the plug may be bad or bent?
The plugs on most headsets are molded type and not repairable or replaceable.
But, before you buy a new headset, I would either try it on a different PC (a friend's if you don't have another) or try a different headset on it, to sort out which is really the problem.
12 Jun 2015   #5
matthewk
As Firebeard said, it may well be the plug on the headphones than. I just assumed that you tried another pair of headphones before suspecting the jack on the computer. Have you tried another pair of headphones? If so what do they do?
12 Jun 2015   #6
GokAy
Regarding repairing plugs and whatnot: I guess it depends on where you live. Here I can take it to a repair person and they can fix pretty much anything. It is cheap too.
My Logitech G35 had its cable broken from where it entered the headset, shielding and a couple of wires exposed. Also one side not working. That cost me 22USD. Logitech G500 mouse, double clicking on both left and right buttons, took 7.4 USD. These include workmanship
12 Jun 2015   #7
fireberd
In the US, many items would cost more to repair than to replace. Its sad, but the way things are.
I'm a former guitar amp repair tech. Today, if I were still doing repair I would have to charge absurd prices just for parts. I had a Focusrite Saffire Pro 40 recording interface unit develop a problem on the main board. The unit cost $445 new, the only place that repairs Focusrite equipment in the US quoted me a price to repair it that was more than I paid for it new. Their labor charge is 2 hour minimum at $100 per hour. The new board (they don't repair them) was $200 (and I would have to wait as parts come from England), plus shipping costs both ways which would have been approx. $50.
Laptop speakers working, but headphone jack not working only on Window
Hi, I have a dual boot of Fedora and Windows, and when I boot into Fedora, my headphones work fine. When I boot into Windows 7 64bit, my headphones don't work. My laptop speakers work fine however, and I tried re-installing drivers. I made sure that my headphones are the default playback...
(Realtek) Upgraded to Windows 7 64-bit, headphone jack stopped working
This happened when I first upgraded from Vista to 7 32-bit last year, when the front output jack stopped working, and I ended up getting an extension cord to travel from the rear port. Now I've upgraded again, and none of them work. I've got up to date Realtek codecs. Any help is...
speakers and usb jacks and headphone and mic jack not working
hello guys i know i am new here and this is my first post but i just really need help with this problem. so i took off the back of my sony vaio e series because the fan was overheating alot so i wanted to clean it out, so i did. when i put the laptop back together the sound was gone as well as the...
My laptop speakers are working fine, but the headphone jack is not!
Hi, I have an Hp625 running Windows 7 Basic 32 bit - I can play music through my laptops built in speakers without any problems, but when I plug headphones (or external computer speakers) into the headphone jack no sound comes through them (and simultaneously the laptop speakers go mute). My...
Front input headphone jack does not work
I recently run into this problem. The first time I tried to use it, it seems that the green jack for my headphones doesn't work at all. Plug in any pair and they don't even recognize it being there, as seen in Control Panel. What might be the problem? The case has a bad jack, or the connector...
Can't Get Headphone Jack to Work
I see that a lot of people have had this problem, and I have been trying to fix it but I am out of ideas. I have a Compaq Presario V3000 and ever since I installed Windows 7 Pro 32-bit, the headphone jack doesn't work. No entry for Headphones shows up in my Playback devices. I am pretty sure it...
