Windows 7: Dobly Advanced Audio V2 not working in Speaker Properties ....
21 Jun 2015   #1
fahadhum
Windows 7 Home Premium 64 bit
I was watching a Youtube video when , i noticed the sound was a bit low even after turning it to the MAX.
So,as usual i went to my sound settings & clicked Speaker Properties to Enable Dobly Adbanced Audio V2 , (Kindly See Pic # 1) & use some Equalizer options , such as Treble , Rock , Soft etc ...
I am getting this Error , (Kindly See Pic # 2) ...
What do i do ... ?
Dobly Advanced Audio V2 not working in Speaker Properties ....-pic-1.png   Dobly Advanced Audio V2 not working in Speaker Properties ....-pic-2.png
21 Jun 2015   #2
fireberd
Reinstall the Dolby and see if that fixes it.
21 Jun 2015   #3
fahadhum
I did that.I got help from this link ,
Service & Support | Acer Official Site
Followed the instructions by the user "Abubakar" from the above mentioned link (Kindly see Pic # 1)
After running the Executible file & Installing it.I recieved this error (Kindly see Pic # 2)
Note : "Dobly Advanced Audio" Executable didn't work , as the user suggested.Besides I have "Dobly Advanced Audio" installed as default , so perhaps that's why "Dobly Advanced Audio" Executable won't Install on my system.
Dobly Advanced Audio V2 not working in Speaker Properties ....-user-help-instructions.png   Dobly Advanced Audio V2 not working in Speaker Properties ....-dobly-install-error.png
21 Jun 2015   #4
GokAy
Did you try running that RegDolby.bat that was in the error dialog in 2nd screenshot from earlier post?
21 Jun 2015   #5
fahadhum
Quote   Quote: Originally Posted by GokAy View Post
I couldn't locate that particular file from the Drivers folder via "System Files" Folder of my computer. Also , i couldn't find any such file through " Start > Search" option in my laptop. ..
23 Jun 2015   #6
fahadhum
Ok Guys.I just got this issue fixed.Thanks to someone giving solutions on this vary seven forums website.He said something about an Acer Recovery Management Tool/Software that is installed in the system when you bout Acer Laptops (I presume , in ALL Laptops).
So,i ran my Recovery management tool and it said , it will uninstall the Audio Driver then will reboot my system and will install and once again i need to initiate/run the setup.So,i did and wholaa , I finally got Dobly Advanced Audio Manager V2 back.
Thank you all for the support...
Unable to get speaker working although device manager says working ok
Hi, Asus MoBo P7P55D LE, I tried to update my drivers using a program that detects new drivers. Unfortunately when it had finished, I did not have any sound. Speakers plug into the rear panel and headphone into the front panel. Been into the device manger and all devices are working correctly. ...
Need some help with audio/speaker systems
Ok, so currently I have a old sony analog receiver with 8 large analog speakers. They sound nice and all, but with the newer ps4 and other hardware I am getting, I would love to upgrade my speaker system on the cheap. As In, not $300 or more. (I am getting married after all lol) The ps4 only has an...
Chillout Room
Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio
Hi, hope you guys can help/guide me out. So I receive a gift a couple of months ago, but did not have the chance to test it until now. I have a set of audio speakers+sub-woofer, if you take a look at the pics (specially the back.jpg) the speakers are connected through a RCA cable, and where...
No Speaker audio - Headphone audio okay
My wife has a dual boot operation using Windows 7 and Ubuntu 14.04. Here is the situation: There is no audio in Windows 7 through the speakers. The audio is okay in Windows 7 through the headset. The audio is okay in Ubuntu speakers and headset. I can't determine what happened to the audio...
Speaker working but builtin microphone not working.
I have Win7 Ultimate in my Compaq Presario CQ60 Laptop. Sounds driver is working properly but microphone is not responding.
I Properties/Advanced Use SSL's grayed out windows 7
I am not a novice and I have tried everything I've learned since 1990 to repair this with a Repair Install (got to much to lose). I have a couple of text copies of my registry and even swapped Internet Settings, Internet Explorer hives etc. Ad nauseam from those registry texts and still get this...
Browsers & Mail
