Windows 7: Audio problem Win 7 32bit
06 Jul 2015   #1
spike47
Windows 7 home edition 32bit
Hi
I am having a lot of problems with the sound recording from my webcam and using skype , it seems to be a windows problem ! , when I go to manage sound devices I get the screen shot as per below but every time I unmute and slide the sound along it just goes back to mute and the slider goes to 0 .
cheers
spike
06 Jul 2015   #2
fireberd
The first thing I see is you only have "High Definition Audio Devices" which usually (in every case I've seen) means you only have the generic, basic function, Windows installed sound driver. First step is to install the correct sound hardware driver (for example Realtek, IDT, Conexant, etc).
From your System Specs, check Intel for a sound driver.
Acer Extensa 4630z laptop sound/audio driver problem Windows 7 32bit
My Acer Extensa 4630z laptop sound/audio driver on Windows 7 Ultimate 32 bit not working. It was working few days before but stopped suddenly. I tried all the audio driver from Download Drivers and Manuals | Acer Official Site. By the way there is no audio driver for Windows 7 so I even tried Vista...
Drivers
Conexant ac-link audio drivers for WIN 7 32bit not working
Hi. I upgraded my OS to Win 7 on a Toshiba L25-S121. Everithing works perfect excep for the audio. Tried installing oem XP drivers in Compatibility mode and worked once. After restarting the PC the red cross at the speaker icon came back and the "This device cannot start. (Code 10)" was displayed...
Drivers
Audio driver for Intel 945PVS Mobo running Win7 32bit
When I have downloaded several drivers from Intel the High Definition Driver S/PDIF is the only one that installs. I've tried removing it from device manager, downloaded and installed the driver that Intel says will work, but no luck getting audio to the green 1/8th inch jack of the onboard audio....
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Windows 7 32bit High Definition Audio Controller not working (code 10)
I recently purchased a used computer from a random individual. it is a powerspec 7123 and appears to be recently reformatted with fresh install. I get home, hook up the basics (ethernet, keyboard, mouse, monitor) open and reboot it installed about a dozen updates. I am downloading programs like...
