Windows 7: Sound crackling, clicking etc. when playing sounds
08 Jul 2015   #1
Repa24
Hello there,
I just got myself registered and I have some problems with my sound which now exist for ~ 6 months.
1. Problem:
You could describe the problem as a sound clicking or crackling. Those appear in various situations, for example when playing a MP3, videos from YT, gamesounds and so on. Mostly they occur when the sound starts or ends (for example a cut in a film), even the simple windows-sound when adjusting the volume has this problem, when i rappidly klick on the volume-slider.
Things i tried, nothing of them helped:
Reinstalled Windows 7 two times, bought a new headset (QH-95), bought two different soundcards (Asus Xonar D1 and Asus Xonar U7), bought a new mainboard (ASRock Z77 Pro3, same as my old one), updated all drivers (reinstalled windows), checked the sound with the Latency Check-programm (everything is green), tried playing the sounds without soundcard (Asus Xonar D1) , changed sound frequienzies, played audio without WiFi on, played audio without any devices (apart from headset and mouse) and defragmentaded my harddrive.
There is still no solution until this day. I slowly start to belive i'm the only one who can hear those sounds, it's just crazy and and the same time also depressing.
Examples of videos where the crackling appears for me:
5:29 - 6:00 (continiously)
https://youtu.be/DxAgB3EI2vk?t=5m29s
1:08 - 1:15 (continiously)
https://youtu.be/HIvQvIEsHZM?t=1m8s
1:21 - 1:22 when he starts driving over the kerb (again, "at-the-start-of-a-sound-clicking")
https://youtu.be/iYlQ_OD68Gc
Video made by me; right after the downshifts 0:10 - ...
https://www.youtube.com/watch?v=sEMhWOz6y-c
2. Problem
This should be easier to resolve: Sometimes i get, out of the nowwhere, extremley loud "white noise", example: https://www.youtube.com/watch?v=1KaOrSuWZeM.
After i stop the audio (for example Youtube-video), the problem stops.
Also, my right headphone sometimes stops working, but it can't be the headset because it works perfectly on my smartphone and on other devices. After a restart of windows the problem is solved.
PC Specs:
ASRock Z77 Pro3
Intel i5 3570k (was overclocked, but resetted it)
8 GB RAM
ASUS HD 7950
1 TB HardDrive
Thermalright HR-02 Macho (CPU-cooler)
Senneheiser PC360
Asus Xonar D1
Logitech G400 (Mouse)
Logitech G510 (Keyboard)
Logitech Driving Force GT (Wheel)
Now it's your turn. Those are the most frustrating PC-problems i ever had, hopefully somebody can help me.
Regards,
Florian
21 Jul 2015   #2
ICIT2LOL
Hello and welcome Florian mate sorry for the wait but it is a strange problem.
Now what immediately pops up for me is you equipment on an electrical circuit that is quite close to anything that uses microwave devices - phones, ovens, wireless communications or even wired communication stuff ? ham radio??
Now another thing that I think of is the sound card sitting snuggly in that slot and are the connecting cables also a snug fit?
Now I suggest you clean the slots and sticks cards etc first. I also have to assue all drivers are up to date?
SLOT CLEANING
Now as for the slots toclean them use a strip of old credit card (or any card thin enough some arebetter than others ) about 1/2 inch wide nip the corners off one end - preferably round them offhold a piece of thin lint free cloth over theend dab on some form of alcohol - isopropyl alcohol (what we swab the skin withbefore an injection) is good and GENTLYswipe along the slots.
This can also be done for the GPU slot/s andalso the contacts of the sticks or cards - not the stick but some lint freecloth of course. See my pic for the stick but please be very gentle doing it ifyou are in any doubt - please ask before doing it but I use this all the timeand have yet to damage anything.
Lastly but not necessarily the end can you read my ditty and post back your findings
Using HW Info
PART A:
You can test the volts on the PSU with HW Info HWiNFO, HWiNFO32/64 - Download < download the right bit version and close the right handwindow select Sensors and scroll down to the power section where you will seewhat the volts are doing see my pic. In my pic the section (Nuvoton) with VBATT is a dead give awayyou are in the section for the rail voltages. There are other section titlesand one that pops up often is ITE
Now the voltage on the different rails have to be within 5% =+/-of what is required or the machine will not work properly if at all.
See this for the rail voltage info
http://www.tomshardware.com/reviews/power-supply-specifications-atx-reference,3061.html (Section 2.)
The original right hand window shows the machine running and ishandy for that but for looking at the components in some detail close it anduse the main left hand side panel
FOR OTHER COMPONENTS
PART B:
Open each small square with + in it on the section thecomponents are in and then click on the individual component/s (it will highlight in blue) - in the righthand side will appear all sorts of details including brands speeds and otheressential info that particular device. See pic for example.
Use PART A: It may seen an odd ask but PSU's are more of a problem than most would like to think
30 Jul 2015   #3
Repa24
First of all, thanks for the answer!
I skipped the slot-cleaning part because I have doubts if that works because the mainboard is acutally pretty new (since 2 months) which is the same as the old one. So the issue shouldn't refer to "dirty slots".
I also read your link and used the tool to show the voltages. For me the values look good (CPU, +12V, +3.3V, +5V, the same when i have a game running), but you should maybe have a look on the values because i'm not very experienced in this.
01 Aug 2015   #4
ICIT2LOL
Sorry late reply mate had problems myself the PSU we can rule out as the rail volts check out ok and would not be supplying the board with bag values and in any case it has that inbuilt circuitry that will not let the machine fire up if any of the rails were bad. It is just sometimes the values can be a just that little low or high to throw things out.
The slots point taken the card contacts though just check them.
Now it just needs to keep looking .
02 Aug 2015   #5
skywalker991
windows 7 64 bit / windows 10 64 bit
Quote   Quote: Originally Posted by Repa24 View Post
Hello there,
1. Problem:
2. Problem
PC Specs:
ASRock Z77 Pro3
8 GB RAM
ASUS HD 7950
1 TB HardDrive
Senneheiser PC360
Asus Xonar D1
Regards,
Florian
It looks like we have the same issue although root cause may be different... I have popping like in your first link, recorded here: https://app.box.com/s/0gutgyjmpn8gbcuwz9r0nz0lqa7de1dq
I've been trying to sort it out for a while (1 months) and tried quite a few things (will list them later - it's rather long list) to no avail but worth noting is that this issue occurs regardless of sound hardware: onboard (realtek), 2 internal sound cards, spdif external dac, 2 x usb external dacs. Which makes me think that it's some kind of Windows resource conflict (resource sharing?) is causing all this.
02 Aug 2015   #6
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
skywalker991, would you please start your own thread about your issue. Just go here http://www.sevenforums.com/sound-audio/ and press the big orange New Thread button. It is too confusing to have more than 1 OP in a thread.
02 Aug 2015   #7
skywalker991
Quote   Quote: Originally Posted by essenbe View Post
sure will do. apologies
02 Aug 2015   #8
essenbe
No problem, just trying to keep things straight.
11 Aug 2015   #9
skywalker991
Hi, not sure if you tried Uni xonar drivers already UNi Xonar Drivers official page - MaxedTech
I had similar issues with sound as you and these drivers fixed my sound. Give it a go they may help
31 Aug 2015   #10
gavinh87
Win 10 x64
Did you ever get to resolve this?
I'm having the exact error on completely different hardware which makes me think it is a windows issue.
I've also tried and external sound card (soundblaster omni) which just amplifies the noise if anything.
This is a second motherboard as it appeared the first was faulty. (Asus z170-a which had an alc 982)
turns out this is the same.....
Asrock Z170 fatality with realtek alc 1150 soundcard
i5 6600K
16gb ddr4 ram
gtx 970
corsair 240gb ssd
I will create my own thread I just wanted to see if the op had made any progress.
Trouble with right front speaker: crackling/popping sounds
I bought some Logitech Z506 surround speakers for my PC, but after hooking them up I found the front right speaker (the one with the thick black cord) was making a crackling/popping sound. So I took them back and got another set and the exact same speaker was again making a crackling/popping...
Crackling sound while playing music, games etc.
Hi, Earlier this year, I came to this forum to get help for a BSOD problem. I found out that it was caused by my onboard soundcard which I have now replaced with a seperate soundcard from Icidu (PCI 7.1 Soundcard Optical S/PDIF In & Out - Soundcard - Audio). I have tried several soundcards...
crackling sound while playing media
i hav a acpi x86 baseb pc. my hardware config are motherboard- asus p7h55mlx ram-4gb hardisk- hitachi 1tb sony dvd writer intel core i3 540 processor sound blaster 5.1 vx
crackling sound while playing audio
I installed win7 64-bit in my pc 2 weeks ago and found a crackling sound while playing audio.I checked that all drivers are up to date and working properly.I later installed xp in D drive and found audio working fine.I dont want to uninstall win 7.Please somebody help. thanks in advice.........
SRS Sandbox suddenly producing only static and crackling sounds!!
Hello! Well, I have had SRS sandbox installed and working perfectly for a few months now. Last night, upon restarting my Laptop, it no longer worked! It only produces horrible static and crackling sounds. This only occurs when SRS Sandbox is enabled. This literally happened upon a restart of...
Windows 7 Realtek crackling/popping sounds.
I get crackling/popping sounds it my games. It's very annoying because it also affect my fps. I tried different driver version and different audio settings but no luck. I notice that it all started after I installed Battlefield Bad Company 2, after I installed my new video card (ATI Radeon HD 5770)...
