Windows 7: Can LPCM audio play to audio card analog outputs?
14 Jul 2015   #1
NickMDal
Windows 7 professional 64 bit
Hi. I have 2 W7 machines, and only one will play the LPCM 16 bit, 2ch audio from a camcorder. Both machines have realtek HD audio.
The machine that plays it has optical audio out to a receiver. The machine that cannot play the audio has analog outputs to a logitech speaker system.
Should LPCM audio be processed by realtek and sent to analog outputs? Am I doing something wrong?
15 Jul 2015   #2
fireberd
Both should play. How the sound card routes the audio output doesn't matter. Its just based on the input to the sound card.
Check the Sound Panel/Recording section. Set the one that doesn't play the same as the one that does (if they are different).
Generally, Stereo Mix should be set as the default Recording device. Then whatever input has sound will be heard.
15 Jul 2015   #3
NickMDal
Thanks for helping. Have boiled it down to the difference in camcorder MTS audio compression types between the old and the new camcorder. The old canon XA10 audio (dolby digital 2ch) works on the both W7 machines.
The Canon XA20 uses LPCM 16 bit, 2ch and will not play on the one W7 machine but will on the other. The Realtek codecs are ALC 889 (problem machine) and ALC 892. Any way to resolve this?
15 Jul 2015   #4
fireberd
The K Lite Codec Pack should install the needed Codec.
Give it a try.
Free Download K-Lite Codec Pack 11.2.0
15 Jul 2015   #5
NickMDal
I appreciate the suggestion but don't trust that sort of app. Here is Microsoft's advice on all-in-one codec solutions.
Quote:
Use caution when installing codecs that you find on the Internet, particularly some of the free codec packs that claim to include codecs from a wide variety of companies or organizations. Incompatibilities are known to exist with some of the components in these codec packs that can cause serious playback issues in the Player and other players, lead to system corruption, and make it difficult for Microsoft Support to diagnose and troubleshoot playback issues. For these reasons, we strongly discourage you from installing these codec packs, and recommend that you remove them
I would rather learn which player apps and chipsets support which codecs, and then install a product that lists the LPCM encoding capability. K-Lite lists 3 product levels with no indication of what each constains.
15 Jul 2015   #6
NickMDal
Found solution. One machine had an older version of VLC. Works now!
16 Jul 2015   #7
fireberd
Great. But, I've used the K-Lite Codec packs and never had a problem. They have been around since the Win XP days.
How can I use 2 audio outputs at once?
I use an HDMI cable to connect my PC to my TV to watch TV shows. I would like to separate and choose what program audio comes from which device. I would like, say for example, Garry's Mod to come from my PC speakers while Windows Media Player comes though my TV speakers. When I go to start>search>...
Cannot get two audio outputs from one soundcard
Recently I purchased a new headset. It connects to the computer through two 3,5mm jacks, a mic out and a sound in. (Never buying anything without USB again...) My regular speakers are also connected through a 3,5mm jack. I've attempted to keep my speakers plugged in the rear and my two headset...
2 audio outputs? Help with sound card
Hey, I know this is a topic that must have came up so many times, but after trying several methods on Google, I've had no luck. So yeh, I'm wanting to have 2 separate audio outputs. So I first had an output coming from the motherboard. I then added a sound card as I beleived this would allow me...
How do I configure WMC to have two audio outputs?
My computer is in one room and TV is in another. I use the stereo plug to power the small satellite speakers at the computer and the HDMI cable from the mother board to drive the TV in the adjoining room. I would like to have sound in both rooms, but WMC seems to restrict one to either/or......
Media Center
One PC, Two monitors. Two Audio outputs possible?
I found this gem of a forum when I finally upgraded my computer recently, used it plenty of times, however got a small issue that I thought this forum could out with. My setup Dell XPS 8300 ATI HD 5770 Gfx card Windows 7 Home premium 64bit Standard widescreen monitor connected to the...
