Windows 7: Sound within specific programs are not recognised by mixer or played
26 Jul 2015   #1
LiamtheDon
windows 7 Ultimate 64 bit
A few days ago I had to perform a cmd scan to have my computer actually work windows explorer after not being able to locate some files (error 127 i think regularly came up) and sound before then among all programs worked.
I have performed multiple cmd scans, update or attempted to locate many related driver updates amongst all recent windows updates. I have reinstalled my sound drivers and still this problem occurs.
since then sound has worked in the majority of programs such as browsers or video sources from them and system sounds, itunes audio originally didn't work either but I think I started windows sound based program in regedit which then fixed that. However other files such as MKV video files sounds do not play or are even listed up in the media player in the windows mixer, I have checked within multiple similar types of these programs internal setups and still no avail from Visual novels to mobile game emulators to no avail. however ordinary games still work within programs such as steam.
I assume windows is unable to recognize sound from more uncommon file types from a specific windows program from before becoming disabled, yet I have no clue how to fix this and especially not in some cover all method unlike what I had to do for my itunes fix.
27 Jul 2015   #2
fireberd
Based on your original problem, I suspect a complete reinstall will ultimately be needed to fix everything.
Random sound played with webcam being plugged in
This is a very strange and very creepy problem and I wasn't sure which forum to post this in. My webcam is normally plugged in 100% of the time. For last few weeks I haven't used it because it fell down behind my desk and I was too lazy to get it again. I am skyping with my friend right now and...
Hardware & Devices
Looking for a specific game I played in the past.......
I am looking for a game I played on pc a little while back. It was called Curves, but I can't find it on Google and no way to get back to it now. The basics of the game was that you had a box with straight and curved lines that did not connect across, you would rotate them so they connected...
Gaming
how to apply a specific sound to a specific action
I have an audio file (mp3) of a toilet flushing , and I would like to make it so that every time I delete anything , I want to hear the toilet flush. what is the easiest way to apply that sound to the delete action ONLY , and what format do I need to convert my MP3 into so that it will work...........
windows 7 sound mixer
I have windows 7 OS on my laptop. The default audio output is the inbuilt speakers. I also have a wireless headphones set. When I connect to the headphones via bluetooth it is recognised and I can change its volume from the volume mixer. But I am not able to control which programs play on which...
Sound Mixer Issues
Not so much an issue, as a general question. Is there a mod or update that will allow you to select which audio output device a program will use? I know some programs allow you the prioritize outputs, similar to Skype, but I am an avid fan of ... "home videos" and it would be rather embarrassing...
No sound on m2ts file from blueray played on wmp
i tried to play m2ts file from blueray in wmp i get video but i dont get audio of the file how to get audio of files from blueray
