Windows 7: My solution for microphone not loud enough
02 Aug 2015   #1
BogdanH
Windows 7 HomePremium 64bit
My specs: Win7-SP1-64bit, Asus P8P67 motherboard
I didn't use/need headset on Win7 till now. I used it successfully on WinXP years ago, though. Ok, so I bough some cheap headset just to use it now and then. I plugged them in into rear panel (yes, into right holes!) and, as we can read many times in forums, microphone was not loud enough. Needless to say I tried all settings (there aren't that many, after all), all I could get is increased noise.
As I only had default MS audio drivers installed, I went to Asus web pages and downloaded latest Audio driver for my mobo. It was about 5yrs old.. which is about the age of my mobo. In short, result was the same (mic too quiet) no matter what settings. Darn cheapo headset, I though... need better ones...
I decided for Logitech G230.. and as you maybe guess: same result again!
Desperate and frustrated, I visited Realtek web pages. Not many stuff there, so downloads was easy to find:
High Definition Audio Codecs R2.79 released few days ago!
Download.. install.. Control panel.. Realtek HD Audio Manager..open.. let's see settings...
YES -it works now!!
I know, I should look at Realtek pages first (is easy to be smart after the fact). Still, I'm kinda dissappointed by Asus for not providing up-to-date software for their products.
Hope above will be of some help to some of you
02 Aug 2015   #2
fireberd
Many PC vendors tend to not issue new drivers, unless a device is not meeting their published specs. My ASRock Z77 motherboard is an example of old (but working) drivers. Realtek is an exception to the hardware vendors issuing drivers. Many other PC on-board audio chip manufacturers do not issue drivers to the public like Realtek.
OTOH I've fixed a lot of user problems by having them install the correct sound hardware drivers. Many are only using the generic, basic function, Windows installed High Definition Audio Drivers. Installing the correct hardware drivers, e.g. Realtek, fixes a lot of problems.
CPU Fan is too Loud
I go into the BIOS and no matter what I do under POWER and set the fan to any speed or anything it won't do anything to the fan speed. Is there anyway to slow this fan down because it is screeming.
Hardware & Devices
Got a new fan that's very loud!
Hey guys ! My new Scythe Ultra Kaze fan just arrived. It's currently running at 100 % ,at about 3000 RPM,which is way to loud. Is there any software I can use to change the speed? I've tried with SpeedFan and BIOS. In BIOS,when I click enter ,I have only 2 options,3000 RPM or IGNORED. At SpeedFan,I...
Hardware & Devices
Microphone issues with loud buzzing/robotic sounding voice
A friend of mine recently started to have speaker/microphone issues (sound would cut out at times for her speakers and mic, had to position herself perfectly) and eventually the speakers completely died. She got a new set (Earbuds + microphone on the cord) and that worked fine for a few hours....
Built-in Webcam Microphone and Microphone Line-in Not Working
I have a Dell Vostro 1500, running 32-bit Windows 7. It came with Vista, but I upgraded to Windows 7 a couple months ago, which I think is causing the issues I'm experiencing. According to whoever I'm speaking with, the sound for the microphone built in to my webcam fades in and out and gets...
Hardware & Devices
Loud CPU Fan!
Hello World. I have tried everything to no avail, so I respectfully ask for the assistance from some of the Seven Guru's here! I cannot figure out what is forcing my CPU fan to spin faster than it ever has before. It is unbearably loud! I have a HP Pavillion a1520n, which I purchased new 3yrs ago...
Drivers
