Windows 7: no sound in audio
07 Aug 2015   #1
tonybest1
windows 7 ultimate
no sound in audio
Hello yall I am new to the forum and I have a question
I was using some nch software and I did not want to buy some of it so I uninstalled the ones that I did not like.
after that my pc is now saying that there are no sound devices installed and at other times it says that there are no audio devices enabled. I have got all the latest drivers for my the audio, I have a system restore, I have enabled it in the services.msc, I have run virus test, I have gone to the intel and the realtek sites to download the right drivers, I have also the MS troubleshooting on my pc and got the red x on the sound symble. What am I doing wrong?
07 Aug 2015   #2
paul1149
Linux Lite 3.2 x64; Windows 7, 8.1
You reverted to a restore point?
08 Aug 2015   #3
tonybest1
windows 7 ultimate
restore point
yes I thought it would help
08 Aug 2015   #4
linnemeyerhere
Windows 7 Ultimate 64
Do you have the driver disk that came with the computer? If you do then start there.
08 Aug 2015   #5
tonybest1
windows 7 ultimate
hello paul I am wondering if it is a virus or is it my HDMI cord?
08 Aug 2015   #6
tonybest1
windows 7 ultimate
it is a custom build but I do have the Windows 7 disk...do you think that would help?
09 Aug 2015   #7
linnemeyerhere
The mobo came with a driver disk so find that if you saved it.
09 Aug 2015   #8
paul1149
Reverting is a very good idea. Go back to an older point if you can.
My guess is that NCH installed drivers for the video capture, which are dominating the proper drivers. If reverting doesn't do it, go to Control Panel / Programs and uninstall anything NCH. Then go to Device Manager and choose Show Hidden Devices, then uninstall anything from NCH.
 no sound in audio
No sound in back audio panel jack - Realtek HD Audio Manager
Hello, I have Windows 7 Ultimate 64 bit and I have a problem with sound. When I plug my speakers in front panel I have output audio, but in back panel I don't. :confused: My Audio Manager looks like this, but front panel is enabled and back panel is disabled. It does not recognize back...
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
No sound via audio jacks, but sound via hdmi.
I recently done a new build, not with the same specs I have on here; i5 2500k p8z77-m pro sapphire radeon 6870 I cannot get any sound through the front+back headphone jacks, realtek doesnt detect any audio devices, however i can mess around with the settings to get windows to say i have...
start navigation sound (continuation from Sound & Audio)
continuation from this thread: http://www.sevenforums.com/sound-audio/107468-start-navigation-sound-playing-no-reason.html here's the Highjack log file:
System Security
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
