Windows 7: no sound from monitor
11 Aug 2015   #1
WHYMEA4
Heres my little problem that came out of the blue was playing a DVD in pc paused same came back later to finish movie and there was no sound i have searched high and low for the cause and nothing seems to work.
The only thing that has come up so far these DELL'S have very bad audio systems and hardly no back up from anyone including DELL its self here are my specs.
I even went into BIOS and disabled integrated audio still nothing was thinking it maybe connected to GPU,AFTER ROOTING AROUND ON THE INTERNET Was thinking a baseball bat might help.
Operating System
Windows 7 Home Premium 64-bit SP1
AMD Athlon 64 X2 6000+ 126 F
Windsor 90nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 375MHz (6-6-6-18)
Dell Inc
Graphics
Panasonic-TV (1920x1080@60Hz)
1023MB NVIDIA GeForce GT 610 (EVGA) 128 F
Storage
931GB Seagate ST1000DX 001-1CM162 SCSI Disk Device (SATA) 108 F
465GB Western Digital WD My Passport 0740 USB Device (USB (SATA)) 92 F
7GB SanDisk Cruzer Facet USB Device (USB)
Optical Drives
TSSTcorp DVD+-RW TS-H653A SCSI CdRom Device
Audio
NVIDIA High Definition Audio
11 Aug 2015   #2
Hacb
Windows 7 Enterprise x64
if you have headphones, try plugging them in and see if that helps, that we we can work out if it is an issue with the actual sound device or not.
11 Aug 2015   #3
fireberd
What is the actual Dell model number, For example Inspiron 580, etc.
Also, are you using HDMI for the Monitor? or are you connecting analog via the GREEN speaker jack? How is it connected and how is the sound connected to the monitor?
Dell's have the same audio as other manufacturers. Its not "bad". I've had Dell's and I've had other brands and ones I've built myself. The audio in all of them worked good. I deal with audio every day as I have a recording studio (but I do use other audio for the recording studio).
11 Aug 2015   #4
WHYMEA4
HI,Well here's another simple and stupid thing that can go wrong with a PC,the reason i lost sound from my monitor is the HDMI input appears to have stopped working changed to another HDMI input and got sound back,thank's for the input
Monitor sound problems
Today I bought new headphones and went to try them on my computer. The driver software installed but sound would not play through the headphones, so after playing around in the control panel under "Hardware and Sound" i was shown icons for my monitor, my headphones, and my virtual sound output. I...
Anyway to get sound per display/monitor?
I have 2 displays, 1 is a TV 3 meters away hooked up to my graphics card via HDMI and the other other is obviously my PC monitor. I was hoping there would be a way to have sound exclusively on the TV while I have seperate audio on my monitor? Sorry it's a bit hard to explain. Basically I want to...
Play sound through monitor
I would like to have my computer play sound through the speakers which are plugged into the sound card if there is nothing plugged into the audio output on my monitor. That means that when I plug my headphones into my monitor, I want the sound to go from my speakers to my headphones. I'm...
No sound coming out of my TV monitor
So, I hooked up an HDMI cable to my monitor and enabled it and set it as a default device, but no sound is coming out of the TV. I don't know why this is happening. Currently, I'm playing sound out of my speakers. I got a screenie as well.
Getting Sound Out Of Monitor
I have a magnavox hd tv monitor that i just hooked up to a new hp pavilion elite HPE. The external speakers work but the internal speakers on the monitor produce no sound. can't understand why the speakers on the monitor don't work. why do i have to use external speakers to get sound?
How do you get sound to come out of second monitor?
I connected my laptop to my monitor with a vga cable (since thats the only connector that the laptop has), but for some reason, sound is not coming out of the monitor. how should i fix this? i know that the speakers work, since i once got sound out of them, but have never used the speakers since ...
