Windows 7: Sound Plays in Headphones in front jack but ext speakers do not work
11 Aug 2015   #1
Thecomposer132
Windows 7 64-bit
Good Evening Friends,
I have had this problem for a long while now but essentially I am forced to use a headphone setup for my desktop but would really like to use external speakers instead of this current set up. What is confusing me is that these external speakers worked for a good long while then stopped working suddenly. Furthermore I switched monitors to a HP w2207 and was wondering if that had anything to do with it. I have updated Realtek to the current drivers and the premise remains the same. Any help would be much appreciated.
CPU: Intel Core 2 Quad Q8200 2.33GHZ
RAM: 4.00 GB Ram
System Type: 64 bit Operating system Windows 7
GPU: NVIDIA 660 GTX
11 Aug 2015   #2
carwiz
Windows 7 Pro-x64
Right click the small speaker in the lower right corner of your task bar. Click Playback devices. Is there a device shown with a green checkmark? Post an image of that window, if you can. (Use Windows Snipping Tool then attach the image using the Paperclip icon in the message text header.)
Forgot to mention: When you plug headphones into the front jack, the default action is to turn off the external speakers so that Windows action is normal.
sound plays through speakers and headphones at the same time
hi guy I have just installed my windows 7 ultimate 32bit on my computer. Then i installed Realtek AC'97 Audio sound drivers. I got my sound working and everthing but when any sound is played like music it plays through my headphones and speakrs at the same time help guys
Computer plays sound on main speakers while headphones are plugged in?
Hi! I'm not very good with computers so I need some help with this. When I plug in my head phones my computer does not register them and keeps playing music on the main speakers, I have checked the Sound in the controlpanel but only the main speakers are listed there. I have an Acer Aspire...
General Discussion
Trouble with audio jack. Plays on speaker but not on headphones! Help?
I am running on a Dell Latitude D630. Just recently my audio jack isnt wanting to understand that my headphones are plugged in. I know that my headphones work cause when I would play them on my iPod they would work perfectly fine. I went into my drivers and uninstalled then reinstalled the audio...
HP620 No sound from speakers only headphones work
HP620 laptop running windows 7 32bit Home Premium Plugged in headphones for an hour. When I removed them the laptop speakers no longer function. Checked volume and mute. Checked playback device area and laptop speakers are enabled and indicated as functioning. Only headphones work. Deleted...
Sound plays through both speakers and headphones
Like the thread title says, I plug in my headphones and listen to them quite happily but then wait, oh no, the sound is still playing through the speakers! I've had this laptop for over a year now, upgraded to W7 when it came out; this is my first issue with it. I've had a look at sound in...
Sound plays through speakers when Headphones..
Strange problem! I have some sounds that play through my speakers when headphones are plugged in. For example, if I run Skype, the Skype will play through the headphones (properly), but iTunes will play through speakers, as will anything else. This also happens when playing Borderlands - I have...
