Windows 7: I'm having problems with my 5.1 sound!!!!
11 Nov 2009   #1
Okay here is whats been happening I awhile back i was using the Windows 7 RC i recently got Windows 7 Ultimate which is perfect but except for one thing my sound is not working properly i have logitech 5.1 sorround sound speakers when i play music it wont work no sound even on videos but when i load up the sound drivers and go to test my speakers only a few of the speakers work but the thing is it plays sound but when i go to play music nothing comes out i click on the sound icon in the system tray and it says that sound is playing i turned everything up still nothing i disable some of the recording devices i use a dell Deminson 4600 recently upgraded its hardrive and ram but i had XP after the upgrade and everything was working perfectly sound was good graphics drivers were good but this is driving me nuts!!! i really dont want to go back to xp after waiting about 3 hours to install windows 7 is there a fix around this or something??? i have try everything even installing vista drivers i use sound max drivers by the way. i reinstall windows 7 twice still no sound i really hope someone can help me sorry for my bad grammar and just kinda typing this up with thinking.....
help me please =[
thanks
also i didnt upgrade the pc i just reformatted it and windows 7 RC sound was working fine
11 Nov 2009   #2
Windows 7 Ultimate 64
Here's my temporary fix. Uninstall your sound card's drivers, and restart the computer. Let Windows auto-install the drivers. Then it should work.
The catch is, as soon as you restart your computer, your sound card will be back to not working properly!
Similar help and support threads for2: I'm having problems with my 5.1 sound!!!!
5.1 sound problems. Sound & Audio
Sound Problems Music, Pictures & Video
Sound problems with onboard sound. Sound & Audio
sound problems with Realtek ALC 882 sound card Sound & Audio
Sound problems Sound & Audio
xfi problems with sound Sound & Audio
USB/sound problems with Win 7 Hardware & Devices
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
