Windows 7: Stereo Mix and Microphone problem
12 Sep 2015   #1
GemilMC
Windows 7 32-Bit SP1
I can't really put a good title on this problem. So sorry if the title sucks.
Anyways the problem, right.
Last week I haven't really had this problem.
But today I got it now.
I have a microphone and stereo mix shit tab here and i naturally disable mic and enable stereo mix on skype to get some pc audio on call then disable stereo mix and enable it back. but today i did it and it said currently unavailable. then i disabled the stereo mix and it said no audio devices enabled or something, then i renabled the windows audio service or something. I can't fix it.
bumppp
still nothing
13 Sep 2015   #2
GemilMC
still nothing? its already been 14 hrs or something :c still haven't fixed it so yeah
13 Sep 2015   #3
GemilMC
plshelp
13 Sep 2015   #4
derekimo
Patience. Quit bumping your thread.
Quote:
2) No useless posts, e.g., thread bumping, useless one liners, junk posting to increase post count, and identical multi-postings in different forums.
Forum Rules
13 Sep 2015   #5
GemilMC
ok then
13 Sep 2015   #6
GemilMC
wait no nvm it worked agen sry it fixed by itself c:
Stereo Mix-How To Record Microphone and Music
I have a Dell Inspiron 1545 and have been working on this stereo mix problem for a few hours today. Here's the solution I've found using Windows 7 and the IDT High Definition Audio. This should work for any Window 7 system having the seeming lack of a stereo mix capability. 1. Go to the...
Multiple audio devices, stereo mix and a microphone
Hello, I'll try to explain this as simply as possible... Currently, I have speakers, headphones and the headphone microphone plugged in. I'd like to record my Skype conversations using stereo mix, but stereo mix only picks up what goes through my speakers and not what goes through my headset....
Unable to record both stereo mix and microphone
All right, I'm trying to record both the stereo mix from my computer and sound from my headset's microphone at the same time. I'm using a headset with a headphone and a microphone plugging-in thing, but I only plug in the microphone one so the sound still comes out of my computer. I followed this...
Stereo Mix problem
Hi, first I want to say thanks for reading and hopefully someone can help me! :) So I just bought a new gaming desktop. I plan to stream SC2 through justin.tv. In order to do so, I need stereo mix to work. Currently, I am getting no sound. the meter does not show sound playing while it does for...
Adding microphone input to stereo mix
Hey guys. I've been working at setting some a justin.tv stream for various games. I'm using flash media encoder to capture the stereo mix input which is fine, it broadcasts whatever sound comes from my computer. However, I now wish to include microphone input without having to hear myself coming...
Stereo Mix problem?
Ok so with Vista, I had no problem whatsoever enabling the stereo mix option on my Soundblaster X-Fi Xtreme Audio, but in Windows 7, it doesn't show up.....I've tried click show disabled and disconnected devices, i've tried uninstalling an re-installing the drivers and nothing is working to get the...
Drivers
