Windows 7: Realtek Audio Headphone Issue
12 Sep 2015   #1
Dusty21134
windows 8
Every 2 seconds i get a notifacation that my headphones have been plugged in/unplugged.
i do have headphones, so this is REALLY annoying. i use realtek and many people have this problem but they're not on a laptop/have headphones. can anybody help me? do i need to provide more info? PLEASE HELP ME!!!!
13 Sep 2015   #2
ICIT2LOL
Hello and welcome Dusty mate first up please
SYSTEM SPECS
mate can we have some system specs please as what you have postedgives us not that much to work with and given there are so many manufacturersof components and configurations that do influence what goes on within anygiven machine and OS.
http://www.sevenforums.com/tutorials/180324-system-info-see-your-system-specs.html
Then I would run these if you have not already in safe mode
http://www.sevenforums.com/tutorials/433-disk-check.html< if necessary include the /f and /r in the command line as per Option2
then these
http://www.superantispyware.com/
https://www.malwarebytes.org/lp/sem/5/?gclid=CJTmq6iGpscCFYqCvQodbfMN1A(free version and untick the trial option when it comes up
http://www.bleepingcomputer.com/download/adwcleaner/
ADW download from bleeping computerdelete any rubbish found with the malware scans
(Anyone running Kasperskyinternet security will find it rants about ADW - ignore it or disable Kasperskywhile running ADW)
Audio coming from both Headphone and Speakers when headphone used!!
Hello Guys, had this problem while,tried many of the solutions to resolve and failed,finally reset the system to factory settings thinking things will be back to normal,but still it exists!!:cry: *Asus g74sx- windows 7 ultimate,Realtek Hd audio. Just saw the new Realtek Hd audio driver...
Realtek HD Audio Issue - Sounds flat
I just recently upgraded from Windows XP to Windows 7. I have always used Realtek HD Audio drivers because they provided the best sound for what I was looking for. However, with the recent upgrade to Windows 7, the sound is very much different, giving sort of a flat sound to it. Before...
RealTek Audio issue
I'm a home worker for a company that requires I use their dialer and web interface. At first I had an issue with clients not hearing me. THAT issue was solved. The problem that exists is this: I need to use the front mic/headset jack on my desktop to use for work. But now I plug my desktop...
Quadraphonic sound issue with Realtek HD audio
Hi. I have a problem with the quadraphonic sound in my computer. I've installed Windows 7 RC and the realtek HD audio drivers just yesterday, and when I configure the quadraphonic sound in the Realtek audio manager it seems to work fine. In the tests, the four speakers sound clear, but when I play...
RealTek HD Audio - sounds in applications issue
Hello: I know less about hardware than I do about everything else, so please indulge. And I have found so many threads re: RealTek HD Audio, but they don't seem to apply to me. Mods, please feel free to merge this to another thread as needed. Problem: Sounds/sound effects for SOME (but not...
Front audio problem and Realtek Issue
Hi i'm having an issue with my front audio jack, the mic works kind-of (when i hit listen i can talk and hear myself through the speakers but when i try to record it sometimes says cannot detect recording device and sometimes it records but scilence) but the headphones do not (When i go into sound...
