Windows 7: SoundMAX Integrated Digital Audio problem
27 Sep 2015   #1
MikiSoft
Windows 7 Ultimate 32bit
I was having an issue with AC'97 audio driver which refuses to install (although it says that it's installed after series of system nagging screens for untrusted driver installing) and then Windows installed some driver via Updates which doesn't appear to work correctly. There is a delay in audio and I can't even click on these Microphone items here:
Has anyone had this problem?
EDIT: Okay I've tried to install again AC'97 driver and it succeeded without any warnings. When I restarted the computer I got this but now with no sound:
All is clickable so it doesn't crash anymore. For the no sound problem that I'm currently facing, I've tried to find Sound Manager to see its settings but I found it only in C:\Windows directory and it doesn't open when I double-click on it. So it appears that it is wrongly installed or something prevented installation to do so. I've tried to uninstall it and then install it again, but the problem still remained - the only difference now is that Microphone (Realtek AC'97 Audio) became Ready and Line In became "Currently unavailable".
27 Sep 2015   #2
MikiSoft
It seems that I was installing wrong driver because Driver Magician told me to do that. I've found that my motherboard (P4P800S-X) has only a driver for sound card which is suitable for Windows XP and that many people have problem with sound on versions above it...
27 Sep 2015   #3
MikiSoft
BSOD, can't shutdown properly - Tech Support Forum
Okay I've made it similar like this above (the difference is that I installed for Windows 2003 driver instead), but next problem occurs - BSOD at shutdown which is causing smwdm.sys. Seems like other people had the same problem but nobody tried to resolve it up to the very end. S**t...
28 Sep 2015   #4
fireberd
XP drivers are not compatible due to some sound functions are processed differently than XP. We saw a lot of sound incompatibility on the Dell forum when users converted to Vista. The ONLY option if there are no Vista/Win7 drivers is to install a separate sound card that is compatible.
Forcing non compatible drivers to install can have untold consequences.
Digital Audio S/PDIF problem
So guys,I havent been turning on my pc(using win 7) for like a month,when i did it was saying Digital Audio S/PDIF and no sound was going nor through speakers nor through headphones.Before that everything was working fine.So,since i had some viruses on it i reinstalled win,formated both...
Problems with SoundMAX Integrated Digital HD Audio on ASUS P5Q Deluxe
I am back with another problem. Recently I have been experiencing total silence from my speakers, I have tried reinstalling the drivers I got from the Asus website several times but with no more success. Currently the drivers do install without any problems, however under the output devices...
SoundMax Digital Audio Drivers for Windows 7 Ultimate?
Hello, All! Here's my system specifications, so please tell me where can I download SoundMax Digital Audio Drivers for my Windows 7 Ultimate? Please give link? I've tried my best but I couldn't find drivers for Windows 7 yet. (I've uploaded my system specifications in .zip format with this...
SoundMAX - SoundMAX audio device not detected
It seems that my Windows 7 installation is getting worse by the day on my desktop (see specs linked to my account). It is just issue after issue it seems. Now my audio is not working on Windows 7, but on my Linux installation it is which leads me to think that a driver issue has arisen....
Hardware & Devices
HD audio device soundmax -a driver problem
Hi Guys, I recently installed the SupremeFX X-Fi Audio Card that came with my ASUS Maximus II Formula. It worked previously on my 2.1 desktop speaker for a while but just few days ago I got issue with soundMax. I tried unistalled and reinstalled the software from DVD that came with it but...
No sound on Intel 845 board in a MPC ClientPro345.. Soundmax Integrated Digital Audio
Have tried numerous drivers
