Windows 7: Disable change of default audio output device when using BT
07 Oct 2015   #1
Raider82
Windows 7 x64
Hey everyone.
Currently I'm using the Realtek on-board sound chip on my ASRock P67 Pro3 Sandy-Bridge generation board, plus I have connected a second screen (TV really) via HDMI to the nVidia GTX 670 graphics card.
A recent change in circumstances has required me to add another (wireless) device, which is mainly needed for the output of spoken language. For that reason I decided to buy an affordable Bluetooth soundbar with an integrated microphone, because the technology is both wireless and the quality of the speakers is hardly of importance for the required task.
I got the device paired successfully and the Bluetooth speakers are available to be chosen as an extra sound device. So far so good, but there's one problem: as soon as the Bluetooth connection is made, Windows decides without asking for my input by the way, to switch off the pair of headphones which are connected to the audio out on the mainboard and starts using the soundbar as the default audio output device on a system-wide level.
That's a nice feature actually for many circumstances, but I need to disable it somehow. Ideally, I would like the sound settings of Windows to remain exactly the same, no matter if a Bluetooth device capable of playing back audio is connected or not. When required, I would switch on the Bluetooth speakers and use a specific piece of software to work with that specific device.
Is a configuration like that possible on Windows 7? If so, what do I need to do to set this up? I've looked around in all the Bluetooth settings but didn't find anything that came close to being a solution to the problem.
Any help is greatly appreciated.
Regards,
Raider
09 Oct 2015   #2
rvcjew
7 Pro x64, 10 Pro x64
Windows will do this regardless by design but you can quickly swap back to it with audio switch.
https://code.google.com/p/audioswitch/
https://drive.google.com/folderview?...0k&usp=sharing
12 Oct 2015   #3
Raider82
Windows 7 x64
Thanks for your reply.
I guess I could do the same on a command-line basis with NirCmd using a scheduled task. Is there any harm in setting it to run every x seconds? If so, is there a way to get the current default audio output device on the command-line?
12 Oct 2015   #4
rvcjew
Quote   Quote: Originally Posted by Raider82 View Post
Your milage may vary. Creating a shortcut to change the default audio device in Windows
Unable to change default audio playback device
I have speakers and a headset set up and previously i was able to switch between which device the audio played out with no problem. However, when i click set default audio device nothing happens. The button is still bold and when i test the device sound still comes out. I have reinstalled their...
Hardware & Devices
No Audio Output Device is installed, HDMI Audio Out Works
No sound. Little speaker with the red 'x' appeared yesterday I have gone through the whole update drivers circus to no avail, my laptop can't detect that it has speakers built in so it doesn't bother finding a driver for them. This is where I am at: - Intel Display Audio is the only driver...
need "always on top icon & msg for "default audio input/output device"
I need to always display the default audio input and audio output device currently on win7. Would like to launch a small program on change as well or instead. I tried to use task scheduler but was not able. Help! Thanks, Ray
how do i make mc7 default audio output separate from system default
I have searched the internet for a solution but am not able to find one. My issue is that i would like to be able to have media center audio play only through my tv and not through my pc main speaker system, tv is hooked through hdmi output on graphics card, speaker system through 5.1 output on...
Media Center
Batch file to change default audio device
Hi all, I have my computer hooked up to a home theater system. Most of the time, my computer audio output is set to my on-board motherboard audio connected to simple speakers, but I frequently switch the default device to digital output through my sound card (HTO Striker 7.1). My goal is to...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
