Windows 7 Forums Search
Windows 7 - Low audio volume problem on Macbook Pro
11-13-2009   #1
7 Ultimate
Hey there,
I've just installed Windows 7(x64) on my macbook pro(the new 2009 model). Everything runs fine, I really like the look and feel of Windows 7. I think its even better than OSX.
Just a small problem with audio. The audio volume is really, really low. The loudest is like two clicks when I'm running OSX. I tried to find a better driver on the net but no luck.
Is anybody else here using the same machine? Have you found a way to fix this yet?'
Thanks for any input.
Dave
 Low audio volume problem on Macbook Pro problems?
Similar Threads for: Low audio volume problem on Macbook Pro
Audio Volume Sound & Audio
Problem Installing Windows 7 Ultimate x64 on a MacBook Air Installation & Setup
Problem with Win 7 on a Macbook pro Crashes and Debugging
Windows 7 problem on Macbook Pro (Bootcamp Partition) General Discussion
MacBook Pro with Windows 7 OS max volume Sound & Audio
